Questions on how to install a fan for Amp??
Old Sep 26, 2003 | 11:36 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
How do I wire a fan to come on with the amp??
Old Sep 29, 2003 | 01:31 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
can anyone tell me how??
Old Sep 29, 2003 | 02:14 PM
stiers's Avatar
I just did it for my project and here is what I did. You need to go to radio shack and get a automotive grade relay:
http://www.radioshack.com/product.as...5Fid=275%2D226
I took a wire from the Battery(+) terminal of the amp, the Ground, and the remote turn on wire and ran those three into the relay in their respective locations and then the positive and negative from the fan.
Old Sep 30, 2003 | 07:09 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I did the same thing....so that the fan will run as long as the amps are on, and it will turn off when they are powered down.
Old Oct 1, 2003 | 09:35 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Cool!! Thanks guys for all the help
Old Oct 4, 2003 | 09:21 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What if I want to wire 2 fans for one amp can I wire them both to the same relay and would there be any need for a fuse??
Old Oct 4, 2003 | 10:01 PM
stiers's Avatar
fuses are always a good thing. I believe the relay should be able to handle both fans. THere is no way they pull more amps than the relay is rated for.
RazorN8
Jan 7, 2022 11:44 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
Leggman1
Aug 6, 2015 04:15 AM
