subwoofer mounting depth
Old Oct 30, 2003 | 09:27 PM
Makaveli's Avatar
how much space should be behind the subwoofer magnet for the sub to breathe? im building an enclosure for my kicker 10" L5, fully powered, so i dont want to choke it from breathing, and my design now is 1 3/8" from the back of the box, and im thinking thats too small.
any suggestions/numbers? thanks
Old Oct 31, 2003 | 02:12 AM
iusedtobebrober's Avatar
Car: 1985 firebird
Engine: 2.8 173 v6
Transmission: The one it came with
Hey my car looks like yours, except i have no primer, american racing rims, windsheild vinyl, and a rear spoiler. As far as the sub, im no expert but i have made my own boxes, i think id go 2 inches minimal behind the subs magnet if you have the box made already and do not want to add depth to it you can always cut a spacer board for the sub and mount it to the front of the box, and make sure you keep as close to the recomanded vas, aka air space for the sub, if you do have to go a little smaller then recomended go to walmart and buy polyfil, if you go to big then you can glue some styrafoam (i think thats how its spelled) blocks like the crap thats used in packages. good luck post how it turns out. :lala: :lala:
Old Oct 31, 2003 | 10:42 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
My subs are about 1\2 in from the wood on the back of the box, and they're fine.
Old Nov 1, 2003 | 12:01 PM
Makaveli's Avatar
i think i got the mounting figured out, i have around 1 5/8" now, so i think ill be ok. anothe thing i wanted to know, is if the box is only 9 inches or so from the top of the well, am i still going to hear it? i see a lot of ppl with the boxes a lot higher, so is the lower box going to effect the sound much?
Old Nov 1, 2003 | 02:08 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
U will here it fine.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
84 TA NV
Sep 6, 2015 08:02 PM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
