amps
Old Nov 3, 2003 | 10:28 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
amps
whats a good amp to go with 2 type r12s in a sealed box???
Old Nov 4, 2003 | 07:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which ones do you ahve? the dual 2ohm, or the dual 4ohm?
Old Nov 4, 2003 | 08:45 AM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
JBL 1200.1
Old Nov 4, 2003 | 09:43 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
JBL 1200.1s are nice for sealed boxs. (They have no sub sonic bass filter, which isn't a problem in a sealed but you need one for ported). They put out 1200 watts at both 2 ohms and 1 ohm. I have one on each of my subs (18" CVRs). There pretty nice amps and they won't bust your wallet. They might be too much for 2 12" Rs... but if you run the subs at 4 ohms you could get 600 watts out of it and have plenty of upgrade capability to power about anything you could want later. Or if you're really short on cash. You could try the JBL 600.1 for about 70 to 80 bucks less. It puts out 600 watts at 2 ohms and 1 ohm.
Ikesound.com has the 1200.1s for 260 bucks and the 600.1s for 190 bucks.
Old Nov 4, 2003 | 02:33 PM
3.492rs's Avatar
Car: 89 IROCZ
that amp is perfect thanks guys
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
