Late model GM CD players........
Old Nov 6, 2003 | 09:00 AM
War_Eagle's Avatar
I am interested in finding out if a newer model CD player from a Gran Prix will fit and work in an 86 T/A? I can get one with EQ for nothing from a friend, but I know little to nothing about car audio and need to know if it will work and if I'll need anything else for it?....
Old Nov 6, 2003 | 01:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
radio is a radio. At most, you're just going to have to wire up an adapter. Mounting might take a little creativity, but physically it should fit.
The newest style GM radios with the speed-sensitive volume are VERY clean radios, and when you use a good quality line output converter, can sound very good.
Old Nov 8, 2003 | 01:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Depends on the year of the Gran Prix. I have traded the factory AM/FM radio from a 93 Cavalier to my 87 with no problems, except that was when my stock radio took a crap on me, I bought an aftermarket CD player, and un-hacked the hacked wiring in there to put in the new headunit. I am not totally sure about this, but if you are just switching stock radios, you shouldn't have that much work to do other than to switch the mounting brackets over from one to the other.
Old Nov 8, 2003 | 01:43 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It should work, but it all comes down to what year this GP's radio is??? If it is before 2000 then the only problem you may come across is unlocking the theftlock which isn't too bad to have doen, but if it is newer then 2000 these radios are vehicle specific to the VIN # within the ECM and Smart box. So if it is too new it will not work for you as your car cannot except this type of system. HTH's??
Old Nov 9, 2003 | 08:10 AM
War_Eagle's Avatar
The radio is from a 1999 GP.... and the theftlock is supposed to be disabled.........
Old Nov 9, 2003 | 11:52 AM
Engine: 2.7L V6
Axle/Gears: 4.41
If the connectors on the back are not the same, you'll have to wait until you can get the harness for the headunit from a similar car.
Old Nov 9, 2003 | 06:58 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
But would you still be able to hook up a rca cable from it to a amp?
Old Nov 9, 2003 | 07:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Does it have the RCA preouts on the back? If it does, then you're all set.
Old Nov 9, 2003 | 08:02 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Guys.. this is a factory stereo from a 99 Grand Prix. So no it doesn't have RCA outputs. Mind you Jensen and a couple of other companies sell high pass adapters, but....
Old Nov 9, 2003 | 08:41 PM
_max_'s Avatar
its called a pontiac monsoon and i have 1 installed in my car 84 camaro had to modify the heater ducts in console and get plug-in from a 94 TA interior harness to make it work
Old Nov 9, 2003 | 09:51 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Actually, Jensen makes an adaptor for their amps for a situation like this. It's called a High Gain input connector and I am not using mine at the moment, becuase I have a different setup. However, this is only for Jensen amps, but the setup I am using is with standard speaker wire with RCA terminals crimped on the ends to connect into the amp (I used this because I had originally connected my amp to the stock headunit that did not have the preouts, and did not remove them when I put in the new headunit(s)).
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
paul_huryk
Oct 1, 2015 04:27 PM
mfp189
Sep 27, 2015 09:25 AM
