What style radio wiring harness for 84 Z???
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey, do any of you guys know the radio wiring harness style for an 84 Camaro? I think there are a couple different styles. I want to get one so when I get a CD deck and want to remove it for some reason all I will have to do is unplug it instead of cutting wires. If someone could help me find one also that would be great. Thanks.
Mike
Mike
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's only one style available for that year. It's the same one GM used from the dawn of time until 88-89. It's a 3 piece harness.
Car: 83 Z-28
Engine: LG4
Thanks do you know what the 89-92 ones used? Do you also know what the newer camaros used? Thanks
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
if your looking for a install harness all you do is goto any car audio store. Most have them for all years. and if anything i just went to crappy tire and found mine there for like 9 bux or something like that. all you do is look for company of the car and find the correct years for them gm is like 82-88 or something like that and they have a nother bracket for 89-92 and i think one more for 93-00's its fairly simple to put in all you do is connect the wires on the chart that comes with harness.
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
you could just do a knotted tap splice in the wires you need and save the $$ for a new CD. this wouldn't take much more time if you connected your new harness directly to the factroy wiring and you would not ruin the factory harness.
wal-mart does carry these aftermarket harnesses for about $12 for most cars.
Car: 83 Z-28
Engine: LG4
