18" IDW in my z28
Old Dec 14, 2003 | 04:52 PM
learsieglerZ'83's Avatar
Car: 1983 Z28
Transmission: 5 speed
18" IDW in my z28
Alright, so ive come across an amazing deal on an Image dynamics IDW 18 and i was wondering if anyone on this site has ever put an 18" sub in the well under the hatch. I know theres enough volume in there for the specs of the sub and i know it could be done, possibly lots-o-fabrication, but i need some ideas of what to do...ie...placement of the sub..etc. so if anyone has any pics of 18s in there car please post away...this is what ive got now 2 IDQ12s.
Old Dec 14, 2003 | 07:01 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
from the looks of it, there wont be enough airspace for a nice ported box unless you glass it and get creative. Im walling my 18s but they require more airspace than yours
Old Dec 14, 2003 | 09:49 PM
Car: 1983 Z28
Im definatly not going to be putting my IDW in a ported box. i have been doing a lot of reading on Aperiodic enclosures and it seems that this would be the best bet for my situation. only problem with this is that it is a hatchback and i would have to cut out part of the bottom of my car....which i may be wrong but i believe theres a gas tank under there. so it may be tricky but SQ wise it would be the best way to go.
Old Dec 15, 2003 | 12:00 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
I am sooooo jealous
Old Dec 15, 2003 | 09:32 AM
Car: 1983 Z28
well maybe you should buy the old one
Old Dec 15, 2003 | 04:52 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You can fit 2 18"s in the hatch well, but it's gonna have to be sealed. I have 2 18" Kicker CVRs in my well. The box is raised above the gas tank area and branches forward. It's around 1.8 ft per chamber and it has a divider wall. There was no cutting to the car involved and yes there is a gas tank under the sheet metal in that area so there's little if not fab. you can do the metal.
Here's the proof there 18"s!!
Come here to see the pics in a bigger format (you got to click on the thumbnails).
Planning on redoing the box with a fiberglass type sometime before Spring. Place to watch for clearance is the top area. Mine actually hit off the hatch plastic so I heated it up with a torch and bent the plastic in no more problem now.
Old Dec 15, 2003 | 05:56 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if you're wondering if there's enough room to put it in the lower half or underneath the well cover, no. the diameter is too big. however, if you're using the entire well, yeah, you can find enough space if you're good with angles
Old Dec 16, 2003 | 12:35 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if you're hardup for airspace you can always mount the sub inverted
Old Dec 16, 2003 | 09:44 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Heh, would the hatch even close?
Old Dec 16, 2003 | 02:13 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i think so...it would be close though
its tough to tell without knowing the mounting depth
Old Dec 16, 2003 | 06:24 PM
Engine: 383 SBC
I couldn't get my kickers to down fire even if I put them flush against the sheet metal above the gas tank area.
Old Dec 16, 2003 | 07:04 PM
onebadwagon's Avatar
SQ with an 18???
that seems somewhat of an oxymoron to me.
adam
Old Dec 16, 2003 | 07:14 PM
Car: 1983 Z28
youve never heard and IDW then have you
Old Dec 17, 2003 | 12:23 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Originally posted by onebadwagon
SQ with an 18???
adam
thats not at all true...im willing to say that my 18s are better SQ subs than most 10s out there. The myth that larger subs are sloppy is totally untrue, most larger subs have a more powerful motor structure and inturn are able to produce accurate sound.
Old Dec 17, 2003 | 08:09 AM
Engine: 383 SBC
There's a big difference in tightness though, course 10s and 12s gonna sound tighter. I think I get fairly decent sound out of my 18s. I wanted them for pressure though. Like I said mine just won't hit as fast as a pair of 10s or 12s, course when you see how much more cone space they have then it all understandable.
Old Dec 17, 2003 | 08:55 AM
it depends on the sub of course, but even with the larger motor structure, pushing and pulling that large cone/spyder and coils is going to get very hard to do, depending on what type of music that you are listening to.
im not saying it all sounds like farts, but it would most certainly not be my choice for SQ.
adam
Old Dec 17, 2003 | 09:00 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
well if a 10 inch sub had the same motor structure as an 18 inch sub then obviously it would be able to respond quicker as the cone is much lighter, but most companies use the same motors for their 10-12 inch subs then a larger one for the 15-18 subs. Or some have a totally seperate motor structure for their 18s. It really depends on if they're designed to be SPL subs, SQ subs, or both
Old Dec 18, 2003 | 09:20 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
whatever you do please put them in an mdf box not the cheap *** particle board. And made sure the subs air space needs are ment. It makes no sence to even have 18s if you can not supply the proper air space.
Old Dec 19, 2003 | 10:14 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
All I gotta say is what the heck u need 18s for? I personally dislike anything higher than 12s...But if it sounds good to u more power to u!
Nate
Old Dec 19, 2003 | 12:11 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Nate
how come you dont like anything more than 12s?
Old Dec 24, 2003 | 08:11 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Same reason ppl rather go for 10s compared to 12s.... 10s hit clean and respond good. The bigger the sub the slower itll bump. Certain music doesnt handle to good to bigger subs. Ex. A fast pace techno song wouldnt handle to good to 15s or 18s... You know the drill... Need I really explain. 15s--18s etc are mostly used in competitions since they need less to make them louder. Also in comps it doesnt matter how nice it sounds just how loud it is. Which is a big crock of ****. Who cares how loud it is...I wanna hear some kinda music coming out of it too.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
