My new sub enclosure
Old Jan 24, 2004 | 06:40 PM
rs_boy's Avatar
Car: '89 IROC-Z Convertible & '91 RS
Well, I've been working on a custom sub enclosure for my '91 RS. Here's a picture of it finished and installed. Just thought I'd share with all you car audio freaks out there.
Old Jan 24, 2004 | 09:47 PM
heavyhopper's Avatar
Car: 1984 z28
Transmission: 5spd
nice and clean
Old Jan 25, 2004 | 11:21 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Can I see a picture with the t-tops in there as well?
How do they sound with the tops inside?
Old Jan 25, 2004 | 11:31 AM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
I did the exact same thing although yours look a little nicer
Old Jan 25, 2004 | 02:06 PM
rs_boy's Avatar
Thanks for the compliments guys. I don't know how the t-tops are gonna fit in the back with the new box. I don't know if there's enough clearance. I would try it right now, but being at 7300 ft. there's about 6" of snow on the ground and it's still snowing. But I was able to get some more photos yesterday before the storm hit us...if anyone is interested. Thanks again.
Old Jan 25, 2004 | 06:42 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
No problem. Let me know when you can.
Old Jan 26, 2004 | 11:38 PM
rs_boy's Avatar
I have a question for all you guys...do you think I should get some grilles for the subs or just leave them the way they are?
Old Jan 27, 2004 | 12:24 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Grilles.
It only takes one can of pop, one golf ball, or one jack handle to make you realize you should have gotten grilles.
BTW, that's a nice, clean install.
Old Jan 27, 2004 | 04:59 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
ya i would go with a grille...there are some pretty nice ones out now...check parts express
or you can buy the scosche spinner grilles
Old Jan 27, 2004 | 06:13 AM
Engine: 5.0L TPI
Axle/Gears: 3.08
To be honest, after seeing the picture of the install... I don't think that I would bother with grilles.
Not to put down anything anyone else said, their points are vaild, but I think that if you try to store anything back there now, you deserve to have something break.
There is no room for you to safely put anything back there in my opinion. Therefore there is no reason to spend the money on a set of grilles. Not to mention the fact that I always thought the "non-grilled" look was cooler looking in the first place.
Just My $.02, like I said.
Old Jan 27, 2004 | 06:36 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Ya I dont got grilles either. Cuz well theres no room back there for anything to hit the subs.
Nate
Old Jan 27, 2004 | 09:21 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
If you plan on putting anything back there, then go with grills.
I have my subs on little humps, so not too much can roll onto the subs.
I also use a blanket when I am carrying things back there on long trips, it acts as a kind of speed bump to stop stuff from getting to the subs.
I'd feel safer with grills. But I would like them to complement the rest of the setup of course.
Old Jan 27, 2004 | 08:24 PM
rs_boy's Avatar
Thank for all the input guys. I think DigitalMonarch0 has a point about the grilles. I'm certainly not gonna be storing things back there with my setup. Plus, amps get hot and need to breathe and they can't do that with **** piled on top of them. I'll look around for some grilles and if I find something that accents the setup, then I go for it. It's all cosmetic from here. Thanks again guys.
Old Jan 28, 2004 | 04:12 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
My enclosure is exactly like that. Yours looks awesome man. I haven't been running any grilles for about a year now and no problems, however I dont' throw **** back there either. So yeah, if you are planning on storing junk back there you deserve to have something break, otherwise don't worry about it.
Old Jan 28, 2004 | 05:03 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
How is T-Top storage for you? Do they fit back there with that setup?
I've got 2 RF 12's waiting for springtime, but if I can't store the tops back there, I probably won't do the install.
Old Jan 28, 2004 | 08:42 PM
305RSlc's Avatar
Fortunately, I dont' have to worry about storing T-Tops, cuz unfortunately I dont' have them. I see absolutely no room though to put them anywhere. My box just sits flat on the ledges in the well, it doesn't go all the way down to the bottom, yet. I honestly wouldn't have done this one if I had T-tops. I'll get a pic once I can get my f****** digital camera to work.
by the way, I have 2 Sony Xpolde 12's and a 800w Sony amp for sale if anyone is interested.
Old Jan 28, 2004 | 09:04 PM
305RSlc's Avatar
hmm....picture didn't work, oh well, try again later
Old Jan 29, 2004 | 12:26 AM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
your install looks good. as for the grills, don't do it. get a 1/4 in sheet of plexy glass and mount it about 2 in above the subs. you should still be able to use your t-tops bag and it'll sound really good to. my cap and dist block mount underneith the recessed amp. the plaxy glass is held up by pvc pipe cut 2 in long and a bolt going through them. my box is ported, don't do that. i used a dremel and cut some slots into the plexy for looks, didn't change the sound at all. have more pics if wanted.
Old Jan 29, 2004 | 12:27 AM
ace16a's Avatar
Engine: 5.0 TPI
another shot
Old Jan 29, 2004 | 12:29 AM
ace16a's Avatar
Engine: 5.0 TPI
sorry, i'll try it again
Old Jan 29, 2004 | 12:46 AM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
i bolted my box down and will be putting grilles on, gives potential thieves more to fuss with if they figure their gonna take my subs at least it puts some more time into getting em off
Old Jan 29, 2004 | 02:29 PM
rs_boy's Avatar
Hey ace16a, I like the looks of your box. The plexi-glass across the top is very original. You mentioned NOT porting the enclosure. Well, I'm not planning on it. Actually, while I was building the enclosure I decided to cut a piece of MDF to separate the box into two equal airspaces. So now it's a little over 1 cu. ft. per sub, as compared to both subs using the same airspace. The bass sounds tight and that's the way I like it. I have a question for you...Does the plexi-glass effect your amp's ability to breathe?
Old Jan 29, 2004 | 05:06 PM
305RSlc's Avatar
Why is it a bad idea to port the box? I would think if anything it'd help to amplify the sound and keep the body panels from rattling as much. could someone explain this please?
Old Jan 29, 2004 | 06:20 PM
ace16a's Avatar
Engine: 5.0 TPI
i also have my box chambered and no, i've never had my amp overheat in the 3 yrs i've had it in that box.
Some subs do sound good ported, but they usually require a large amount of air space, something not found in a third-gen. Unported boxes sound much better.
Old Jan 29, 2004 | 06:38 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
some subs dont require a lot of airspace and therefor would work well ported in a third gen...it really depends what subs you're using
Old Jan 30, 2004 | 12:21 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I have found that ported boxes seem to have a bit of a vibrating sound as the tube vibrates from the bass.
From the enclosures I have heard, as well as the ones the people I talk to have heard, a non-ported enclosure is more likely to produce a better and even range of bass, while a ported box is usually really loud for a certain freq of bass.
They both can sound good, it just depends on your listening preference. What you listen to and what equipment you have.
Old Jan 30, 2004 | 12:36 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i think what you're talking about is port noise...which wont be existent if the box is designed correctly
a low tuned ported box will have excellent SQ with the right sub
Old Jan 31, 2004 | 03:36 AM
91-formula-lo3's Avatar
Car: 91 formula
Engine: 5.0 tbi
[QUOTE]Originally posted by 305RSlc
[B]My enclosure is exactly like that. Yours looks awesome man. I haven't been running any grilles for about a year now and no problems, however I dont' throw **** back there either. So yeah, if you are planning on storing junk back there you deserve to have something break, otherwise don't worry about it.
sorry cliked on the wrong one.
Old Jan 31, 2004 | 03:48 AM
Car: 91 formula
Engine: 5.0 tbi
thay will fit i have the same set up in my bird it sounds cool with them in there. almost like a banpas box. if you vent the box on both sides. but then agin what worked for me may not for you.
Old Jan 31, 2004 | 10:20 AM
Engine: 5.0L TPI
Axle/Gears: 3.08
I'm not worried too much about the sound, I don't think that the glass will change the sound quality enough for me to care. My main concern is the T-Tops clearing the top of the amp. I've got these two 12's sitting in my garage waiting for spring, but I won't buy an amp and build a box for them if it's not going to fit.
Kind of a touch spot, I've just never seen a pic on TGO with subs and t-tops in the hatch.
Old Aug 31, 2004 | 03:15 PM
Berlinetta's Avatar
okay, im bringing this post back from the dead to ask you guys how you built those boxes. What are they made out of? What are the dimensions? Do you have pics of the entire box outside of the car?
Old Aug 31, 2004 | 11:01 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
most boxxes are made out of 3/4 MDF
Old Sep 1, 2004 | 01:51 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
If I were you I would just move the amp and build a wood cover with perferated grills in it.You could probably build it up higher to cover the amp too.
Old Sep 1, 2004 | 01:52 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Old Sep 1, 2004 | 05:14 PM
Berlinetta's Avatar
sorry, but i have no idea what y'all are talking about... im a newb when it comes to audio stuff
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
phisherness
Car Audio
Nov 14, 2001 05:20 PM
JannaMan
Car Audio
Nov 4, 2001 08:16 AM
GndPrx
Car Audio
18
Jul 5, 2001 05:35 PM
DJSexay
Car Audio
Apr 27, 2001 10:45 AM
