recommended volume of sealed box question
Old Jan 26, 2004 | 07:46 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i just bought two 10" pioneer subs and got a box for them for free at circuit city. anyway, the subs say the recommended sealed box volume be 1.0 cubic feet +-10%. The box that i got for them has an internal volume of .75 cubic feet in each chamber. will these still sound good despite the difference in volume or should i try to fix the problem somehow? i suppose i could mount them inverted or build a bigger box, but id rather just use the box i have. i also heard theres some sort of polyfill or something like that that you could put on the inside of the box that would make it perform as if it was in a bigger box. what do you guys recommend?
Old Jan 26, 2004 | 08:49 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
That sounds about right.....The Q logic boxes are the same way. My Infinity Perfect 12's require 1.0 each and the Q logic box was measured at .85 ft. I got the box free with one of the subs (bought the other from ebay for about 100 dollars cheaper) and it sounded pretty good actually. Get the foam inserts (looks like insulation for your house....Just smaller ) and that should put you where you want. The inserts do work by the way.
Later
Old Jan 26, 2004 | 09:05 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
heh, yeah the box i got is a q-logic. where can i get the foam inserts and what are the different types? thanks
edit: i found out that i already have some polyfill , so i think ill try that. thanks for the help
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Firebird sweden
Aug 16, 2015 05:02 PM
