amps mounted inside the rear cargo area plastic trim.
Old Feb 18, 2004 | 10:04 AM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
hi again,
my ? for all of you w/ systems in yur 3rd gens this time is...
can or do you have yur amps mounted behind the plastic trim/molding in yur car?
i know amps need some air and stuff to breath but i figure u got plenty of room behind there and ppl hs mounted subs in there that i seen in another post but would amps be ok in there?
i mean like being able to breath and stuff?
ive never had any probs w/ the amp under the seat of the s10 of behind the seat mounted on the back of the cab so im thinkin it wouldnt hurt to mount an amp or 2 inside the plstic trim.
not mounted to the trim but remove it like were the spare tire used to be and make an amp rack fomr plywood or something so u could mount the plywood or rack solid and then attach the amp to it.
but would it have trouble breathing?
as of now my 6x9s push alot of air around in there so im thinkin that may be even better since they are moving air around and its not just settin there.
if anyone has any suggestions or pics or opinions all are welcome thanks guys and girls.
Old Feb 18, 2004 | 01:13 PM
waterstrw's Avatar
Car: 87 Iroc-Z
Engine: LB9
I had mine mounted where the spare tire was at on time.... Now I have both amps under my box in the cubbie hole....
Old Feb 18, 2004 | 01:44 PM
benoit454's Avatar
Car: 86 camaro
they work under yur box as well?
that was my original plan to make a box just for the well in back of hatch the lowest spot and mount my amps to the bottom of the box but tuning them yud have remove whole box and my dads like no u cant do that they gotta breath.
which made sense so i thought about inside the plastic.
thanks for the help any others got em mounted inside or think theyd be ok in there?
i think they would.
Old Feb 18, 2004 | 02:26 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
this is where i have my amp mounted
this
http://images.cardomain.com/member_i...789_7_full.jpg
this is the amp
http://images.cardomain.com/member_i...789_9_full.jpg
Old Feb 18, 2004 | 02:34 PM
benoit454's Avatar
Car: 86 camaro
i seen a couple done that way w/ the bowtie thoose are awesome.
was it hard to make that box for em well not really the box but the cut out for the bowtie to make the bowtie?
and hows them volf's sound?
i seen were i can get them cheap but never heard em they thump hard? n sound good or not?
Old Feb 18, 2004 | 04:24 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
People have mounted amps in the spare tire compartment many times without issue. There is alot of air space in that place.
Regarding under a sub box in the "cubby hole" in the back. A friend of mine has a sony xplode amp there with a sub box similar to mine. It works fine, but it heats up like mad.
Keep in mind the reputation Sony has. Other amps might run cooler.
Old Feb 18, 2004 | 04:40 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
It was a little comlicated, to make, but reltivly simple.
the volfs are good, I like the way they thump. good power fpr the price
Old Feb 18, 2004 | 05:36 PM
learsieglerZ'83's Avatar
Car: 1983 Z28
Spair tire well....the zapco over heated once but it was 100 degrees out an i was playin it all day...it was fine 30 min later
Old Feb 18, 2004 | 05:56 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
thats a good idea too. but I like to show off, and in that compartment, I think not
Old Feb 18, 2004 | 06:02 PM
benoit454's Avatar
Car: 86 camaro
reason i wanted to do it was to avoid being sen so no one knows what i got once its done theyd hear it but wont see it so if its parked n stuff and they decide to lookin or i got the hatch open i wanted em hidden
Old Feb 18, 2004 | 08:57 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
My only concern was in the cooler outside temps condensation can form on the inside of that rearquarter.. Has anyone noticed any corrosion in or around their amp as a result of it?
Old Feb 18, 2004 | 09:14 PM
Car: 1983 Z28
I never have, there are vents in the in the top or the side of mine i believe
Old Feb 19, 2004 | 06:47 AM
waterstrw's Avatar
Car: 87 Iroc-Z
Engine: LB9
I have two amps mounted under my box..... No problems at all.... I also don't ride around with it wide open all the time either... Only when a good song comes on....
I say as long as your not pumping some serious watts and don't have it wide open for lond periods you should have no problem mounting under you box in the "cubbie hole"......
Old Feb 22, 2004 | 10:44 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
KJ Rockz does your amp box block any of your sound? It seems like it would have to. Certain frequencies of bass are very dependent on reflecting off the hatch and into your ears... in my car I can tell a big difference when I put anything back there. I guess it also matter what you set your crossovers at and such... dunno just wondering.
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lee01
Apr 9, 2016 01:56 PM
I'llrocya
Feb 2, 2016 11:43 PM
