speakers won't work
Old Mar 1, 2004 | 07:40 PM
kammi10's Avatar
Car: 1989 camaro
speakers won't work
ok so i put a new cd player in the car today and i hooked eveyrting up righ tbut yet only 1 of the speakers work the front left one. my rears i think i hooked up the wires wrong but then i swapped um and wouldnt; work. checked all wirde and they all have good connectiong sbut still no sound out of them. any idea's
Old Mar 2, 2004 | 03:55 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if you check the fade on your deck and its set properly i would quickly take out the back speakers are wire them yourself directly to the HU to see if they work or not...should take about 10 minutes and a few feet of wire.
you can also test the wires by quickly taping them to a low voltage battery (less than 9 volts) you should hear a little pop from the speaker but be carefull not to hold the wires on the battery for more than a split second
Old Mar 2, 2004 | 07:00 AM
kammi10's Avatar
Car: 1989 camaro
thanks boomin boy i planed on getting a speaker and hooking it up directly to the HU and seeing if its the wire going to the speakers
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
89lsc
Aug 14, 2015 04:58 PM
