subs pound, lights dim
Old May 4, 2004 | 01:27 PM
  #51
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
****, Thats how the v6 guys think they are gonna beat the v8's!
They ground their motors 27 times! Each times 10 hp!? Damn thats 270 ontop of the motors 135 hp! 405 2.8 from ground wires !
Old May 4, 2004 | 02:43 PM
  #52
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i should just put a thread just for the dumb things that have been done to mah car... trust me random wires are cut everywhere... besides the tow hitch on the back and trailer lights in the rear storage thing.....i have no reverse lights and the dome light is mia.. the light doesnt work.
Old May 4, 2004 | 08:03 PM
  #53
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Well I got my new battery and sexah chrome 140amp alt. Well the alt is off to get hacked for more output. Gut said I should see 170-190amps out of it after the rebuild. That with my 1200CCA Orbital Xtreme Duty deep cycle bat should solve the issue. I am thinking of getting one of those battery iscolators and running the 600amp for my cars core compoents and using the 1200 as a battery to power the rest of the stuff.
Old May 15, 2004 | 09:45 PM
  #54
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
2 quick things to add to this...
1) Ground loops are bad Bad BAD, so when you upgrade your "big3", be sure all of your grounds go to the SAME frame screw. Anybody who knows anything about electricity will agree with me here. Ground loops can disrupt the weak PCM analog reference voltages, which can lead to inaccurate sensor readings. And you all should know that ground loops in audio systems are terrible...
2) Deep cycle batteries are for RV's and trolling motors... Don't waste your $$$ putting one into your daily driver. Get yourself a good quality automotive battery with high CCA #'s.
Old May 17, 2004 | 07:00 PM
  #55
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
ROBSGTA.....
your funny man! you crack me up, please keep posting.
sure a cap will 'stiffen' the voltage in a power supply.....which is what the car really is to me, one big power supply.
There has to be power in to get power out...
So can I ask you, where is the cap getting it's power from?
I liked the post about a cap holding about 1000 watts worth of power LOL....1k watt alright.....sure...
Smart cap? no, just a cap. The 'smart circuitry' is a cheap digital voltmeter that can sometimes short the cap and make it useless.
Old May 19, 2004 | 02:21 PM
  #56
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
1. sounds like a good point...makes sense logically.
1.5. it doesnt apply to me anyways cuz nuthin is runnin offa the computer ....
2. Deep cycle only if u run the batt down alot like a tard.....:lala:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
