Newbie amp question
Old Apr 25, 2004 | 12:56 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Newbie amp question
Hi, I'm a newbie on the audio board and I got a question. I am running a sony explode head unit. It is an older one ( before they went all red ) w/ flip face and an internal amp. I have Kenwood excelon speakers 2 4x6 and 2 6x9. I also have a bazooka bass tube in the back. 8 inch with an internal amp. this is pretty good for me but the speakers distort at high volume. my question: do I need an amp? I was told I need a 4 channel amp w/ a cross over. Is this right? A friend of mine has an Alpine V12 4 channel almost new. I can grab it for $200.00 He paid $425.00 for it. Should I go for it or should I look for something else? Thanks in advance-Mike
Old Apr 25, 2004 | 10:59 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
If it's a decently powered amp....it should be at least 75 watts rms per channel for that price, 100 rms is more like it. definitly grab it, those are nice amps. Be conservative with the gain, a little goes a long way...
set the cross over to about 100Hz High-Pass, maybee 120ish for the smaller speakers....but let your ear be the judge. The idea is to get as much sound as you can without distorting the the speaker with lower frequencies (more physical cone movement) than the speakers can handle at one time.
Infact, your bass response will improve due to the amplifier output being 100% within the speaker's actual capabilities. It won't work wonders, but it definity sounds better than the HU trying to squeeze out unrealistic crappy bass. later on you can add a sub and it will actually 'fit in', not just 'mask' bad sounding low end......good luck!
Old Apr 25, 2004 | 11:09 PM
Engine: 2.2
never mind....you already have a sub. just keep the gain down so it doesn't distort too. Also lower the Low-Pass cross over on the Bazooka if you have any distortion problems with it.
You may have to set your crossover as high as 200hz High pass for the front 4x6"s, it's all in good judgement. There is nothing wrong with trying to squeeze just a little bass from the 6x9"s though.
Have fun chasing down new rattles!
Old Apr 27, 2004 | 12:18 PM
Um, thanks I think. I should grab it then right? I will do that today. What about an instalation kit? I see alot for sale on ebay. 7 bucks up to 80 bucks. What should I get?
Old Apr 27, 2004 | 10:41 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
ebay is evil.. im paying more (like 2x as much )for my system becuz i dun trust ebay... get a good one from circuit city or pepboiz or sumplace where if its wrong you can yell at ppl.. in fact go to the store and yell at tehm for slow service its fun...
Old Apr 28, 2004 | 09:43 AM
Ebay rocks! I built my whole car off ebay and these message boards ! Pep boys ? Now they scare me. What should I look for in an installation kit? My local stereo shop has them for 80 bucks but I'm sure I can do better online. just need to know what to buy.
Old Apr 28, 2004 | 10:21 AM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
go to walmart and get their amp kit there, they are good. Or try www.knukonceptz.com
Old Apr 28, 2004 | 08:28 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i personally am goping to use as much monster wire as i can... also the gage of ur amp install kit will determine how well ur system works ie: lower gage lower wattage.... im getting 0gage becuz im planning a 1000+ watts RMS beast
Old May 3, 2004 | 08:25 PM
Engine: 2.2
quality wire is important......but,
do you know what is MORE important? quality installations....
a $10 kit will do the job if you have all the right wires, although some RCAs can be bad enough to actually distort and muffle the signal. I wouldn't spend $80 to hook up an amp though....that's just insane! If you believe the RCAs aren't good enough...replace them.
For $80 you could find an amp and the wires on ebay. There is nothing wrong with buying from the internet if you know what you're doing.
How can you possibly get the 'wrong' amp kit?
Why yell at the people at Pep-Boys? sure some of them are nit-wits, but they are just there doing a $7/hr job. If they knew any more about parts, they would perhaps have a better job in the automotive parts business.
Old May 3, 2004 | 09:03 PM
I was at wal-mart today and I saw their amp kits-not bad. I have a spare rca line and I still have the original wires that came with my new speakers so I guess I will spring for a power line to mount the amp in the back of the iroc above the bass tube and next to the nitrous bottle. I should be o-k don't you think? I haven't done stereo stuff since I was a kid so I'm learning all over again.
Old May 4, 2004 | 02:50 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
a bazooka( tube) seems to bump pretty good in our camaros
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
