Dropped a screw down AC vent
Old Apr 25, 2004 | 02:45 PM
Mr.W's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
Well, I dont know where to post this, but since I was installing new speakers I figured I'd post it here.
While taking off my dash pad, I dropped a screw down the vent near the top of the dash pad. Where will this thing end up? Can I get it out? Will it rattle if I dont get it out?
Old Apr 25, 2004 | 03:47 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
well if you have not done to much.. a little magnet on a string.. I had droped one of my dash pad screws down once.. send a little magnet in after it.. and came back with three screws.. I took the ait box apart behind the dash once .. and there is no easy way of getting into that area from there.
Old Apr 25, 2004 | 04:20 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
This is sooooooooo friggin odd.
I just did the same thing!And was logging on to ask the same question! :lala:
Only diff is I dropped my socket
Old Apr 25, 2004 | 11:18 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
Just saw this the other day....
open up the floor vents and go for a little cruize. Don't endanger yourselfs, but a few sudden turns might help them find thier way out. Good luck!
Haven't you nit-wits ever heard of magnetic tips?
I use the DE-WALT myself, something like $5 at the Home Depot, it's securely fastened in the chuck of my trusty cordless 99% of the time. It's 1/4" hex drive quick change and will temporarilly magnatize just about anything you care to use with it.
Old Apr 26, 2004 | 01:13 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Who hasn't? I've got a bunch of them down there.
Old Apr 26, 2004 | 02:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
get some fishing line and a good magnet.
if you dont have a magnet, any good hardware store should have a couple to choose from.... i like the ring ones the best because its easy to tie to... (shaped like a tire)
tie the fishing line to the magnet and send it down there... if it doesnt get it leave some slack, tie it off to somthing (like the mirror) so you dont lose the end, and go for a drive... do a few hard and quick turns....
as long as what you dropped is magnetic, you should be able to pull it out that way
junior419
Apr 7, 2025 11:35 AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Sep 16, 2015 12:37 AM
lakeffect2
Sep 7, 2015 03:52 PM
