How big of an alternator do I need?
Old May 20, 2004 | 05:25 PM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
I need to get a new alternator, as the bearings are going on my current one. The current one isn't stock. It's a large case one, and it's 70amps (at least that's what it says on the case).
Anyway, I have a stereo, it's a 200W deck, and a sub that's wired for 600W RMS. I'm also thinking of getting driving lights and possibly a neon undercar kit (hold the groans ).
So I'm wondering what alternator I need to get. I know stock is 105, and it seems 140amp and 200amp alts are easy enough to get. Since a 200amp is about twice that of a 140, I'd like to know for sure if a 140 isn't gonna do the job before going for the 200.
I know people say buy the most you can afford, but that's kinda like throwing parts at a problem instead of finding the one part that was the problem.
I've heard it mentioned that a HO alt will produce noise in a sound system. Is this the case all the time? And can this be corrected?
Are the large case alternators better with overheating than the small case ones (like what came stock)? I the 200amps all seem to be the large case ones, but if I should go with a 140, would a large case be better or does it matter?
Any comments/suggestions/explainations are greatly appreciated.
Old May 20, 2004 | 06:54 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
a healthy electrical system is the most overlooked aspect of a stereo system...it never hurts to be overkill....i think you would be alright with a 105 amp alt with that setup but car audio is very addicting and chances are you will want to upgrade in the future so i would go with a 140 amp atleast.
ive never had any problems with my HO alt causing noise in the system and ive transfered it through 4 vehicles so far.
Old May 20, 2004 | 07:13 PM
Engine: 5.7L (L98)
Yeah. I do want to go a bit overboard just to leave some room for the future as you mentioned. If 140 is overkill for what i have now plus some additional lights, then I'd go for that.
I just don't want to be "cutting it close" and finding out later on that I should have spend a bit extra. Unfortunately, I don't have much experience, and the companies all say I should go with a 200.
How much room for improvement does a 140 give me?
Old May 20, 2004 | 08:54 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I have a 140, and it makes a big difference. Plus my yellow top Optima, makes a huge difference.
Old May 22, 2004 | 01:58 AM
Engine: 5.7L (L98)
So I shouldn't run into any problems with a 140? I'd just hate to get it and find out later I should have gone with the 200.
Old May 22, 2004 | 02:16 AM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
Check this out. A 180amp for $135 buy it now and $15 shipping.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33573
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
