4th Gen Steering Wheel
Old May 26, 2004 | 09:57 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I'm about to buy a 4th gen steering wheel. I know it will fit onto my 92 TA, but will the radio controls work? I'm hoping that GM automatically put the all the wiring in place. And will all GM radios work with the remote controls? I have the cassette with equalizer.
Thanks,
JJ
Old May 27, 2004 | 09:44 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
sounds like a long shot. id say no
Old May 28, 2004 | 06:03 AM
widow_maker89's Avatar
the 92 stereo wont work with the steering wheelcontrols luckily the stock 4rth gen is a streight across swap no mounting or wiring changes pull on install the other personally i would go with a stereo from a 96 T/A b4 they went to the monsoon logo on the face sounded better... then you have the eq and the cd player i did this on my car looks sweet be sure the deck you get isnt from the bose system
Old May 28, 2004 | 08:40 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i thought abought doing it with my 91 RS but i did not know what to do with my air bag. will the 4th gen air bag still work?
Old May 28, 2004 | 08:55 AM
i believe that they will work but to be sure look at a schematic of the wiring check voltage and impedance if all lines up then yes physically and athetically yes its a go as far as the wiring a small amount of research will tell you
Old May 28, 2004 | 09:01 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
I currently have a non airbag MOMO wheel. I have a feeling any wiring that was there, isn't anymore. So I'll probably stick with the MOMO. I also have a Grand Prix, and those controls are one of its best features.
Thanks everyone.
JJ
Old May 28, 2004 | 10:38 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i wouldny worry about it. my airbag.... rather all teh wiring int mah steering column save the ign key wiring is cut. i can thank the cars previous owner. i feel safer working on the car w/o the airbag being armed.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
