Conestant Power, install problem
Old May 31, 2004 | 06:48 PM
dru_pe's Avatar
Car: 1991 Firebird
Engine: V6 3.1
Transmission: Automatic
was installing my head unit (pioneer Deh-p3600) the other day, and my dumb *** gounded out the constant, spark, now its dead, checked the radio fuse and its not blown, is there an inline fuse that i cant find, cause i hate having to mess with my settings every time i start my car, please help, thanks
Old Jun 1, 2004 | 03:48 AM
1983SS's Avatar
Car: 1983 "SS" Camaro, 2000 Mustang GT
Engine: .30 350
Does the dome light work? Horn? Did you cut the fuse off of the pioneer constant wire? Check the fuses above and see what happens. Jered
Old Jun 1, 2004 | 09:32 AM
dru_pe's Avatar
Car: 1991 Firebird
Engine: V6 3.1
Re: constent power
horn works, dome light works, checked all fuses under dash, none blown, the pioneer head unit i have diddnt come with in line fuse for constant power wire, should i install one??? cause the last head unit i had worked without one, , if so what amp? if that dont work, where would i be able to pull another constant wire from????
Old Jun 1, 2004 | 11:37 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Re: constent power
No, the 10A fuse in the back of the unit is on the constant, not switched. So there is no need to add one, it will do nothing for you but take-up space and time. The only Pioneers that came with the inline fuse didn’t have the fuse in the back of the radio (different harness). I would double check the under dash fuses, check them with a continuity tester if needed.
Old Jun 1, 2004 | 11:50 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
well maybe you fried the HU.. i would use a fuse if you dont have one already but NEEDAz said you have one. of course itll work w/o a fuse, they just protect the cirucuitry yiu can still complete the cuircuit without a fuse.. hope you didnt french fry you HU tho
Old Jun 1, 2004 | 06:18 PM
dru_pe's Avatar
Car: 1991 Firebird
Engine: V6 3.1
RE
How would i be able to tell if my HU is fried, where is it located???
Old Jun 2, 2004 | 08:00 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
dru_pe, HU is short for head unit.
If it was your 12V constant and it hit ground, the HU should be OK. That is IF the CONSTANT hit GROUND. Any thing other then that and all bets are off.
You need to get in to some trouble shooting now, get a voltmeter or a test light and check for 12V on the constant lead. If you don’t have 12V there then you need to find out why. If you do have 12V there check the 12V switched, then the ground. Let use know what you find.
Old Jun 2, 2004 | 06:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What was the previous radio in there? Was it the factory radio, or another radio? I ask b/c I wonder if someone else put another fuse somewhere, before you got the car.
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
