How do I wire these subs?
Old Jun 16, 2004 | 04:13 PM
loud91rs's Avatar
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
I just got two kicker s10l7 dual 2 ohm subs, and i already had a kicker s10l7 dual 4 ohm sub. how can i wire these so that i get somewhere at 2 ohms or up? thanks.
Old Jun 16, 2004 | 05:33 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I don't think it's normal to mix match up Dual 4 and Dual 2 ohms subs. Check out this wiring page. http://www.jlaudio.com/tutorials/wiring/index.html
They show you how to wire up 2 dual 2 ohm subs to get a 2 ohm final. Then I guess you would wire up your 4 ohm sub by itself to get a 2 ohm final for it. But I have no clue if it's wise or even possible to connect different ohms like that.
Old Jun 18, 2004 | 12:56 PM
treeohfive's Avatar
youll end up with an odd impedance level and your amp will not be operating at its best capacity but...itll work....you would run the 4 ohm speaker in series since its 2 ohm then run the 2 ohm as you normally would ....Then you have 2 2 ohm speakers.....ah...gotta love DVC
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Bryan F
Aug 27, 2015 07:28 AM
