Need help with amp install
Old Jun 21, 2004 | 11:07 PM
85_ZED28's Avatar
Car: '85 Z28
I hooked up a 2 channel amp to my rear speakers in my camaro (6X9s), and they sound great, but the head unit doesnt recognize the rear speakers: If I set the balance to all rear, there is no sound. Basically I think the head unit thinks all 4 speakers are fronts. What did I do wrong?
I plugged the rcas from the deck to the input on the amp, then connect the speaker outs on the amp to the rear 6X9s, so the speaker wires for the rears are just cut off hanging from the deck.
any help is apprecitated!
Old Jun 21, 2004 | 11:51 PM
TestyAmoeba's Avatar
Car: 1989 Firebird Formula
Engine: TPI 350 Vette motor
Transmission: 4spd Auto
Did you plug the amp into the rear output RCA's? It sounds like you plugged them into the front outputs.
Next question would be, how many output's do you have on the back of the HU..
Nate -
Old Jun 22, 2004 | 08:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
if your head unit only has 1 set of rca pre-outs, they may be designed to fade with the fronts. If it bothers you that much, you could always power your front speakers out of the rear outputs of the head unit. You'll have your fader back, but it'll just be backwards in terms of front to back.
Old Jun 22, 2004 | 08:03 PM
85_ZED28's Avatar
Car: '85 Z28
yep thats definalty it, thanks a lot Jim. Thats a good idea, maybe I'll switch it up
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
SPEEDY Z28
Aug 17, 2015 01:46 PM
