this amp is it anygood
Old Jun 22, 2004 | 11:17 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
mtx thunder 500d
came somebody give me the specs if its any good when it was made those type of things. thanks
jon
Old Jun 23, 2004 | 01:01 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Mtx is a great brand and they under rate their amps power wise so they realy pound.
Old Jun 23, 2004 | 01:05 AM
jocww's Avatar
good maybe ill bring it up to tahoe to test it. still need subs. i just found this one so hopefully it works. do you know anything about his amp
Old Jun 23, 2004 | 01:31 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I tis a 250 watt amp at 4 ohms or 500 wat amp at 2 ohms.It is a pretty powerful amp.
Old Jun 23, 2004 | 10:29 PM
jocww's Avatar
what kinda subs could i power
Old Jun 26, 2004 | 01:10 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well any 2 ohm or 4 ohm sub will work.You'll get the most bass out of a 2ohm.Most compition subs are both 2 and 4 ohm.I have a 2 JL audio 12's and they pound pretty hard.
Old Jun 27, 2004 | 03:23 AM
jocww's Avatar
sounds good guess ill have to get another amp and 2 subs hey 87 i kinda need that info on the tahoe thing asap
jon
Old Jun 27, 2004 | 03:31 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well,they have it at our air show.It is on august 23rd.I need to get all of the info on the car show though.
Old Jun 29, 2004 | 09:09 PM
jocww's Avatar
87 pm me or im me if you want info on the show i have it now also since i still dont know if it works or not but if it does im going to try to use it to power my speakers and get a1000 watt amp to pwr 2 12s
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
