Radio goes out....
Old Jun 30, 2004 | 02:19 AM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
Radio goes out....
Hey all,
For some reason, when I turn my stereo onto radio I can listen to the radio for like 15 sec then it just goes fuzzy, I tried replacing the antenna itself,
You guys think I have to replace the whole wire from the antenna to the radio???
Old Jul 8, 2004 | 03:33 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
Your constant to the radio is probably having a bad connection. Check your wiring and make sure everything is crimped or soldered together. Also check the antennae wire and make sure its plugged in securely to the radio. Its the black thick wire with the metal probe at the end. Hope this helps!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
