Which capacitor
Old Jun 30, 2004 | 08:56 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Which capacitor
Okay, I don't know much about the stereo thing, but I do have a question.
I have an autotek ss amp running a 400W Rockford Fosgate HI. Which capacitor should I use?
Also, how much heat can the amp take? It is not in a well ventilated area, and it gets hot here during the summers. I have never had a problem with it in previous summers, but there is no point if half-assing something, right?
tia
Old Jun 30, 2004 | 01:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You probably won't even need a capacitor for that size of amp. If you run into electrical problems it can probably be fixed by upgrading the big 3 wires (do a search).
Mainly capacitors are just extra storage for power in case your system puts so much drain on the battery it can not keep up with the demands.
Old Jun 30, 2004 | 04:58 PM
Cool, thanks dude. I am needing to upgrade B3 already, so will just make sure that it can handle the drain from the sub.
Elephantismo
Feb 13, 2019 12:51 AM
AustinT
Oct 22, 2001 02:40 PM
BahamutRS
Jul 16, 2001 11:50 PM
JPrevost
Apr 12, 2001 05:56 PM
92fireaudio
Car Audio
Nov 6, 2000 10:30 PM
