amp question
Old Aug 11, 2004 | 08:32 AM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
amp question
hey guys, i have a question it might sound kinda stupid but im not sure about it so i thought i would ask. Is it safe to put the amp under like a piece of plexi glass, or should i leave it out so it can get air?
Old Aug 11, 2004 | 09:33 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
It usually depends on the amp's tendancy to heat up.
I have seen many amps under plexiglass with no problems at all.
Unless it really heats up normally, you should be fine.
Old Aug 11, 2004 | 09:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Typically, if you're going to put an amp under plexi, you need to find an alternate source for airflow. Usually when you see amps under plexi, they have built-in fans, or external fans were added, or both.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
