DVC Wiring options
Old Aug 24, 2004 | 10:15 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
DVC Wiring options
Hey all,
Is it possible to wire up 3 DVC Subs to a 2ohm stable amp?
Old Aug 24, 2004 | 10:41 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes.
Old Aug 25, 2004 | 07:36 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Only if they are 4 ohm models, even then they come out to a fractional final ohm. Check out http://jlaudio.com/tutorials/wiring/index.html
Old Aug 25, 2004 | 02:32 PM
AJ_92RS's Avatar
You can do it with any DVC subs.
A 2 ohms DVC sub can be wired in parallel to create a one ohm load, then wired in series with each other to the amp to create a 3 ohm load.
8 ohm DVC subs can be wired to create a 5.33 ohm load buy running them in series, then wired parallel to the amp.
And obviously, 4 ohm DVC subs can be wired in series, then wired to the amp in parallel to create a 2.67 ohm load.
Any of those would be fine with an amp that can handle 2 ohms (bridged). Granted, the 5.33 ohm load wouldn't give you the most power output, but you gotta do what you gotta do.
Old Aug 25, 2004 | 02:53 PM
ThraxXx's Avatar
Sweet my subs are 4ohm. I guess that will be the battle plan that I will use for the new stereo going in my winter car.
Old Aug 26, 2004 | 11:32 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Actually, running drivers in series isn't recommended because in a series circuit, when all resistances are the same( i.e. three 1ohm speakers), the first speaker in line will get more power then the second,the second more power then the third, and so forth. . Only in a parallel circuit will each speaker get the same amount of power to drive each sub. Is this correct?
If using 3 dual coil drivers,I would recommend getting dual 4ohm subs,wiring the coils in series,then parallel the subs to the amp.
Old Aug 26, 2004 | 12:46 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Sorry try again. In a series circuit current will be the same throughout and if ALL the loads are the same resistance, voltage will be divided equally. Current stays the same, voltage divided equally, power divided equally.
E=IR
The power to each load would be the SAME......
Old Aug 26, 2004 | 03:19 PM
RSpeed's Avatar
My fault. You are correct NEEDAZ.
Old Aug 28, 2004 | 09:03 AM
AJ_92RS's Avatar
In all the electricity/electronics courses I've taken (3 to be exact) that was NEVER stated. Normally they don't state stuff that isn't true.
What is true is in a series circuit, the higher load will get more power. I.E., a 4 ohm and an 8 ohm speaker wired in series to an amp... the 8 ohm speaker will be louder/get more power.
That I do know is true. Is this perhaps what you're thinking of?
I suppose I could see that happening with a DC circuit, but not an AC circuit, which is what a speaker receives.
If what you're saying is true, isn't running the coils in series the same thing? Won't one VC get more power than the other?
Old Aug 28, 2004 | 10:07 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Hay, AJ, read the post right above you're post. He just made a mistake.
Old Aug 28, 2004 | 03:38 PM
AJ_92RS's Avatar
I was just responding to him quoting me. That's all.
Old Aug 28, 2004 | 07:59 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
What I see is you're wiring six voice coils to one amp? Consider that bridged, the amp is using only the left channel from the stereo. I'd think about adding another amp and wiring two speakers (four coils) to the biggest amp and the other to the smaller on the other channel from the stereo head. Or something like that. Just a thought.
Old Aug 29, 2004 | 03:46 AM
AJ_92RS's Avatar
What?
Old Aug 29, 2004 | 07:48 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Maybe there is something new out now? Most amps that I've had are bridged to mono. One input channel to both outputs tied together. Take a bridged amp and unhook each RCA input cable and see what happens.
Old Aug 29, 2004 | 07:51 AM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
Actually it's both inputs mono'd to one output 99.9% of the time
Old Aug 29, 2004 | 02:29 PM
AJ_92RS's Avatar
Sometimes 4 chnl amps will do that if you bridge them into 2 chnls by flipping a switch on the side of the amp. It makes it easier for someone to run subs that way instead of having to use 4 RCA jacks for only 2 subs. I know my Alpine is like that anyway.
My friend has a Profile amp (yes I still claim him as a friend) and even with it bridged he had to get "Y" splitters to hook up all 4 inputs on the amp even though it was being run in bridged mode.
But as screamin' said, 99% of 2 channel amps combined both inputs into a mono signal.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
Infested
May 22, 2018 11:56 PM
RedLeader289
Jan 22, 2016 03:05 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
