Whine????
Old Sep 17, 2004 | 07:03 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Whine????
I have a whine in my stereo system. It happens all the time, with am/fm or cd. I tried moving all the power wire away from the signal wires, no good. I have an older jensen cd player. Broke for now, so I'm saving for a new cd/mp3 player. Would an isolator at the alternator help. No amp yet, just lazy and haven't put it in yet. Any help would be great.
Old Sep 24, 2004 | 01:34 PM
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
Re: Whine????
the deck is likely the culprit. try giving the deck a new ground...might help. I wouldn't spend much time on an older Jensen head unit as you might just be chasing ur tail.
bmoney
Old Sep 24, 2004 | 02:34 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Whine????
...I have an older jensen cd player. ...
That you're problem.
Try to run a ground to the chassis of the deck as well as the one in the harness. They have a problem with the ground opening up in the middle audio path, this will give you a lot of noise. They also had a problem with solder connections under the filter caps. Also, a bad motor ground can give you some bad RFI.
This should get you started....
Old Sep 26, 2004 | 04:33 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
you can always try a ground loop isolator. I did that and the whine went away. Its more of a bandaid fix rather then the real deal. Only way to really fix it is to re-do your grounds.
Old Sep 28, 2004 | 09:41 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
First, I would make sure all of the ground wires are connected right, then upgrade the "big 3" with bigger wires, from the block to the ground, the battery to the alt. and the alt to the ground. If you upgrade those wires, you should have less of a problem if it is alternator whine.
Old Oct 29, 2007 | 05:34 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Whine????
mine whines too butt it only lasts like 5 minutes after startup could this be my problem to?
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Youngs92
Sep 23, 2015 11:29 AM
chazman
Aug 22, 2015 02:01 PM
