need amp suggestion :)
Old Sep 30, 2004 | 09:25 PM
85_ZED28's Avatar
Car: '85 Z28
I need an amp that is 2ohm stable amp to power a DVC 250watt sub I have. So 250rmsX1 @2ohms would be perfect! any cheap but good amp recommendations???
thanks for any input!
Old Sep 30, 2004 | 09:55 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
audiobahn a2601t
Old Sep 30, 2004 | 10:03 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Attached Thumbnails need amp suggestion :)-abspex1.jpg
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
A2801T
A3201T
A2601T The A/B MOSFET amplifiers from Audiobahn are the most versatile of the bunch. With remarkably clean power, these amps are ideal for everyday use. They’re strong enough to run subwoofers and precise enough to deliver the crisp, detailed sounds from your mids and highs. With a wide bandwidth and outstanding clarity, you’re sure to hear the difference.
Common Features
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Double-Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz - 120Hz
Bass boost @ 45Hz: 0-18db
Subsonic Filter: 20Hz - 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
Old Sep 30, 2004 | 10:26 PM
85_ZED28's Avatar
Car: '85 Z28
it says 2ohmX1 N/A
Old Sep 30, 2004 | 11:30 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Right, meaning they're not 2-ohm stable. So you cant use 'em.
Old Oct 1, 2004 | 02:20 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
well once i install my jbl amp Ill let u know but im pretty sure they are 2 ohm mono stable, even 1 ohm stable. You can find em cheap on ebay. Otherwise they cost a pretty penny. Theyre good quality though.
I was looking into JL audio but forget about their prices. LOL
Nate
Old Oct 1, 2004 | 06:30 AM
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
the vast majority of class A/B amplifiers are NOT 2 ohm stable. Generally 2 ohm stereo, 4 ohm mono. The exception to this is a high current design, in which case they are usually stable to 0.5 ohm stereo, 1 ohm mono.
class D monoblock amplifiers in the lesser price/power range are generally 2 ohm mono stable. there are plenty to choose from. as you get bigger power, they go to 1 ohm stable.
but being "stable" is somewhat a misnomer. in either a high current or class D amplifier, you NEED to drive the amp in the lowest rated load to get all the power from it. Yes, you can run a 1 ohm monoblock at 4 ohms, but will only be delivering a fraction of the power. this is even more true of high current a/b amps.
look around...believe MTX has a decent little monoblock that makes 200 or 300 clean watts...
bmoney
Old Oct 1, 2004 | 10:07 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well its 2ohms x 1. the x1 means its one channel and since ur running one sub itll work. audiobahn stuff is 2 ohm stable anyways... or if you want the chart list three amps from that class, and the specs i listed are for all of tehm. the only thing that changes is the watts. also those watts are in RMS
Old Oct 1, 2004 | 10:58 PM
85_ZED28's Avatar
Car: '85 Z28
are you sure man
Old Oct 2, 2004 | 07:35 AM
somehow my post on this was deleted what exactly is 2 ohms x 1? I've been in this business 12 years and have never heard of that.
look at the specs in the chart above bud. yes, they are 2 ohm stable, in STEREO. Not many A/B amplifiers go past 4 ohm mono bud, and these are no exception. will they work at 2 ohm mono? maybe (big maybe). will they make more power? NOPE. and the amp will live a MUCH harder life.
you need to be sure of what you're stating for people as they are likely to use the info incorrectly....
bmoney
Old Oct 2, 2004 | 08:54 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
dont bother with amps that arent 2 ohm stable in mono. Sorry to say it man but you get what you pay for. Look on ebay as you can usually get at least a 1 year warranty and about half the price. I was pondering on getting a JBL mono block but Im gonna go with a PG Xenon series. High quality. Its like a 600.00 amp and Im only spending a little more then half of that! It puts out a clean 600.1 @ 1-4 ohms. Look for something you know is gonna sound good and thats at a good price.
Nate
Old Oct 2, 2004 | 09:08 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
omg i cant believe my mistake... yall shoulda made it more obvious to me.. sorry its been a long month.. three hurricanes here in FL and you dont think so straight.. well if you check the audiobahn website here you can go to the products area and look at all the amps... they do have a lot that are 2ohm and 1ohm stable but most of those are either above or below ur 250 RMS.. remember that audiobahn lists all of the ratings in RMS
Old Oct 2, 2004 | 08:55 PM
onebadwagon's Avatar
mtx 421D would be a little overkill, but it can be had pretty damned cheap if you shop around.
adam
Old Oct 3, 2004 | 12:50 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
2 ohm stability has little to do with quality. No different than saying that a V8 isn't as good as a high revving 4 banger because it doesn't rev to 8000 RPM. Different applications. A four channel amp will rarely get driven into a 2 ohm or 1 ohm load, so why pay for that power and not use it?
So most speakers are 4 ohm, most amps are designed with that in mind (class A/B) anyway).
The second half of your paragraph is spot on..
Juan
Nate
Old Oct 5, 2004 | 09:22 AM
85_ZED28's Avatar
Car: '85 Z28
I got one, thanks guys
Old Oct 5, 2004 | 10:53 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
WWW.ALINE-USA.COM HAS A GOOD LINE UP OF MONO AMPS....
Old Oct 5, 2004 | 08:21 PM
trust you mean aPine if you don't mind overpriced bellybutton equipment, its actually not bad. (bellybutton as in "everybody's got one")
There are SOOOOOOOOOOOOOO many good brands that its not even worth listing. Some great bang for the buck stuff are JBL and Visonik...
shop around, and judge with your ears and then your wallet. you'll land on the right product.
bmoney
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
raymondandretti
Sep 27, 2015 06:43 PM
