Thought I'd update my hatch a bit...pictures inside..
Subscribe
Nov 2, 2004 | 05:45 PM
Well...I guess you could call this an amp rack? What do you guys think? I'm not sure if I should put the amp on it...or underneath...that way, it would be hidden...and a bit cleaner with no wires. Any suggestions or thoughts are welcome. Give me some info and idea's guys! thanks
(the amp is just sitting there, not mounted)
Reply 0
another
Reply 0
Nov 2, 2004 | 05:46 PM
with the amp...gone..
Reply 0
Nov 2, 2004 | 05:48 PM
looks good...any info on how you made it?
Reply 0
Nov 2, 2004 | 05:54 PM
Quote:
sure man
I bought a sheet of 2'X4' ply wood. Cut it down to 2 piece of wood. Then, cut an angle to get the tilted effect I wanted. Then, used "liquid nails" to put the 2 piece together, held down with weights to get a very tight fit. Let it dry overnight. Then, I covered the hole thing with a coat of bondo. Blocked the whole thing. Then sprayed it with a metallic graphite textured paint (same as my roll cage), then sprayed a coat of flat clear coat on it. Thought it would update it a little....and it's cool because no wood grain is seen at all...and it's seamless
Reply 0
Nov 2, 2004 | 06:05 PM
looks nice but i think it would look better with the same carpet material like around the speakers.
Reply 0
Nov 2, 2004 | 06:06 PM
I like it. It has the clean no clutter look. Doesn't even look like its made of wood. Good job. I think I would mount the amps on top and the wires under it. Why not show off what you have worked hard on.
Reply 0
Nov 2, 2004 | 06:42 PM
actually, I'm kind of trying to get away from the "carpet" look. I'm thinking about getting a piece of thin wood or something to put over the actual speaker box, painting it with the graphite spray...and blend it in with the rest.
Reply 0
Nov 2, 2004 | 06:50 PM
Just do what I did and put a board with perferated grills in it.You can still use your hatch space.I like your setuo by the way.
Reply 0
Nov 2, 2004 | 07:32 PM
i thought it was covered with a thin leather style material...never thought of your method...how long did it take you?
Reply 0
Nov 2, 2004 | 08:09 PM
That's EXACTLY the look I was wanting. I was wanting to get the effect of a thin leather...like the color of my SS seats. To me...it matches very very well. Painted it was way easier then covering it with a material too.
Because I had to glue it together with liquid nails-let it dry, coat it with bondo-let it dry, block sand the whole thing, spray 3 coats of color-let it dry, spray 2 coats of clear-then let it dry....it took roughly 2 days.
Reply 0
Nov 3, 2004 | 07:40 AM
How about flush mounting the amp into that board instead of sitting it on top? That'll give a nice smooth appearance. Then you can recover the sub enclosure with the same material, and you'd have a real nice looking setup.
Reply 0
Nov 3, 2004 | 11:14 AM
ok, a few more quetions..
1. do you have any pics of you roll cage?/ and where did you get it?
2. what brand paint did you use?
3. if you dont mind...how much was the whole project? ($$ wise)
Reply 0
Nov 3, 2004 | 12:03 PM
Pictures of the roll bar are located on my car dowmain site if you wanna take a look at it. I ordered it from a place in California made by "AutoPower". Here is the link to the site I got it from: http://www.livermoreperformance.com/
The brand is "Duplicolor" and it's a textured metallic spray
The whole project cost about $30 bucks total
That's what I was going to do....but...after I realized it...I already finished sanding it. If I tryed to do that right now..I'm afraid that the bondo would start to crack...and ruin the finish.
Reply 0
Nov 3, 2004 | 01:53 PM
hidden for sure! nice and clean
Reply 0
Nov 3, 2004 | 02:31 PM
I think It Looks good your heading in the right direction maybe this will gve you some ideas on the material to use if its the look you want
Reply 0
Nov 3, 2004 | 02:32 PM
another
Reply 0
Nov 3, 2004 | 03:40 PM
Quote:
I love the covering, where did you get it at??? IT looks like a very darh grey...like an ebony..and that's what I'm looking for. I think it would be best to get cover it all with a covering instead of spraying the rest of it...(speaker box)
Reply 0
Nov 4, 2004 | 02:14 PM
Quote:
The Box And amp rack are covered in black Vinyl..pics dont show colors too good i went with the black Vinyl instead of carpet because it gives it a cleaner look.. i think Vinyl looks better than carpet just my opinion,,,
Reply 0
Nov 4, 2004 | 02:15 PM
The Box And amp rack are covered in black Vinyl..pics dont show colors too good i went with the black Vinyl instead of carpet because it gives it a cleaner look.. i think Vinyl looks better than carpet just my opinion,,, the amps are mounted on a plastic mirror and covered over with clear plexi..
Reply 0
Nov 5, 2004 | 10:48 AM
black88cam, how did you wrap the sharp corners so well in vinyl? is there a tuck that can't be seen in the pics? It really looks great and any insight into your wraping technique could really help me out on a few projects I have in mind.
Reply 0
Nov 8, 2004 | 02:48 PM
Man you guys don't have a hatch area or anything! What if you need to put something in the car?
Reply 0
Nov 8, 2004 | 02:49 PM
Quote:
then it's not a true showcar
Reply 0
Nov 8, 2004 | 02:57 PM
Mine looks like the guy who has the 2 JL 12's except black and no cover my amps are in the spare tire well out of sight of prying eyes
Reply 0
Nov 8, 2004 | 09:15 PM
Quote:
the vinyl is machine stiched on the entire box and amp encloser, hope that helps
Reply 0
Subscribe
