question about my cd player
Old Dec 5, 2004 | 04:44 PM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
when i turn my car off. the cd player resets like if the battery was disconnected everytime..but if i shut if off for like 30 sec and start it back up..its ok..but if its longer than that..its all at default settings..i dont know what it is.. any ideas?
Old Dec 5, 2004 | 06:43 PM
V-Car's Avatar
Car: 90 Camaro RS, 2001 Holden Calais.
Is there a constant 12v wire as well as the switched 12v?
Check to see if its connected to retain memory.
Old Dec 5, 2004 | 06:46 PM
Car: Firebird
Engine: 2.8
Transmission: 5spd
ok ..yea..i forgot..theres the yellow and the red..rite? yellows like.constant..and reds switched? do i connect them? or seperate? im lost with the wiring the guy did on the car when he had it..its all jerry rigged..everythings spliced every place
Old Dec 5, 2004 | 06:49 PM
V-Car's Avatar
Yellow is usually the constant (battery) one which will need to have 12v all the time, and the red will be switched through your ign/acc.
They should be separate, with the yellow hooking in somewhere that has constant 12v, like a wire for interior lights etc.
Old Dec 14, 2004 | 10:28 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
whoa wait a min... just use the factory radio wires... the car has a yellow constany hot for the radio and a red acc wire in it already... no need to splice into the lights
kairles
Oct 26, 2015 09:13 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
