What The Hell
Old Jan 1, 2005 | 12:13 AM
BRILLIANTRED1's Avatar
Car: Brilliant Red metallic RS T-Tops &
Engine: 305 TBI & 350 LT-1(bolt on's)
Transmission: T-5 & 4l60
What The Hell
i hooked up my wires and a Panasonic ca100U HU and i built a box for my sub ....ok i hooked the wires to the sub and then i hooked the RCA's in last ....every tim i hook them up the PROTECT light comes on ....i got the HU wired right and everything else no wires toughing and so i thought , maybe it was defective RCA's so i bought new ones ....no luck im lost i've installed the same setup but with 2 Vegas and they worked GREAT but i cant even get my amp to come on....oh yeah i already tried a diff amp and sill no luck ...im runnin a Planet Audio 1200D amp with 1 "10 p1 RF punch sub
Old Jan 1, 2005 | 01:06 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
check the amps ohm ratings and make sure no wires are touching whatso ever and that the sub is wired correctly, all your positives, negatives ect.. also make sure your terminal isnt touching the pos and neg on the box on the inside
Old Jan 1, 2005 | 01:59 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
you have to make sure you wire the sub right (omes) you cant wire it for one ome if the amp cant handle it
Old Jan 1, 2005 | 06:48 AM
9177's Avatar
Even if the speakers are wired at to low of an ohm load the amp should still come on. Try disconecting everything but the power, ground and remote turn on. Turn on the stereo an see if the ampo powers up correctly. Then turn off the stereo and hook up the rca and turn back on the radio and see what the amp does. Next try the speakers, hooking them up one at a time. This will help you setermine if its the amp, speakers or HU
Old Jan 1, 2005 | 01:05 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
it could be possible your remote lead is dead or your ground isnt grounded properly or many things...Im sure youll find the problem.
You can make a remote lead from a switch and prolly even run it to your cig tray...
Nate
Old Jan 1, 2005 | 04:26 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
yea having teh hu turn it on is mearly a conveniance
... check all ur connections 3 times
Old Jan 2, 2005 | 02:04 AM
well i had the ground grounded to the plastic on the jack ( i got a 4th gen Z now) and i didnt realize it ....but im interested in how you wire it for ohms ....i knew they were rated, so i have a 2 ohm x 2 or 4 ohmx1 (bridged) and a RF P1 4 ohm sub now do i need to do anything more???
Old Jan 2, 2005 | 02:01 PM
Car: 2002 SS
Engine: Ls1
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
theres the site for how to wire a sub properly..
If you kno what your sub puts out at say "500w at 2 ohm" then if your sub is 500 rms then you would want to wire your sub to 2 ohms.. you kno what im sayen.. just wire the sub right for the amp and you wont have problems
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
