Question about installing peel and seal.
Old Jan 20, 2005 | 01:40 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I went to Lowe's and picked up some peal and seal today as a cheaper alternative to the overpriced dynamat. The search button works wonders . Anyway, in my searches, I read that it is better to use a hair dryer/heat gun when you are installing it. My questions is you cut the peal and seal to fit the panel you want to cover(duh!) but do you remove the backing first, install the peal and seal, and then heat it, or do you have to remove the backing first, then heat the backing before you install it? I just want to make sure that I am doing this right the first time, so that I won't have to do this again. Thanks for any info on this.
Old Jan 20, 2005 | 03:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Clean the surface you want to install it to. Carb cleaner works well for this. Peel the backing off the stuff, install it, press it into place firmly and evenly. Heat it, then press it again (preferrably with a roller). You'll feel the difference. It's going to be very hot and squishy, so using a roller will really bond it well to the surface.
Old Jan 20, 2005 | 04:07 PM
86iroclamarque's Avatar
Car: 1986 IROC
Engine: 305ci DEAD FINALLY! 350 almost ready to go in!
Transmission: 700R4/Coming out TH-350 going in!
How much did the peel and seal cost and how much is needed for our cars?
Old Jan 20, 2005 | 08:30 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You may not want to put peel'n'seal on vertical or upside down surfaces if you live in a hot climate. Heard stories of it falling off and leaving a stickie mess behind.
Old Jan 21, 2005 | 03:29 AM
paulmoore's Avatar
86iroclamarque:The roll that I got was 36 inches wide by 33/5 ft long. It did all of my floor pan, headliner area, and rear seat area(for today at least) and I still have a heck of a lot more. Will be doing the rear deck area and the trunk sometime soon. Ooops, I forgot to mention that this is on my sunbird, I mean camaro, yes, camaro.
Old Jan 21, 2005 | 07:27 AM
EjBaL's Avatar
does this stuff work just as well as dynomat? Also..does it double for insulation? I mean the stock crappy padding thats under the carpet and back seat, will this stuff just replace that and help reduce noise and insulate? How much was your roll? Thanks
Old Jan 21, 2005 | 09:23 AM
Car: 1986 IROC
I'm curious to hear from someone who has had this in their car for a while and how the peel and seal compares to the dynomat side by side.
I'd hate to put that in to save a few bucks and regret it later.
Old Jan 22, 2005 | 01:21 AM
Dynamat Extreme is prolly one of the best there is. But it costs $$. There are other cheaper products like brown bread or second skin that are popular. Peel'n'seal was never intended for car sound dampening duty.
Old Jan 22, 2005 | 03:12 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So.... how good are the other alternatives? There must be something as good as Dynamat, but not as greedy!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
