This Amp anygood?!
Old Feb 13, 2005 | 02:32 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
This Amp anygood?!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...EOAB%3AUS%3A54 Says its 1600 watts but I have no idea?
Old Feb 14, 2005 | 01:54 PM
Chilo's Avatar
Car: 91 Z28
Engine: 355 TPI
Transmission: Streetfighter 700r4
Cheap amp
The amp if your lucky can only put out about 25 watts RMS. By the pictures, it shows that it has a blue fuse on it. That means it is a 15 amp fuse. So 15 amps times 14.4 volts equals 216 watts max. Divide that by 4 channels you get 54 watts max per channel. Divide that by 2 and you get 27 watts on normal and undistorted power. And no, you can't just replace fuses on an amp to a bigger size to produce more power. The more current that the fuse lets through to the amp, the more power it will produce. The only thing this amp is good for is for four 6.5" at the most. The amp doesn't even have a cross over for highs, which means that if you want to use it for highs or voice, it will do you no good.
Old Feb 14, 2005 | 05:56 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
looks like a piece of crap
get a hifonics or something for a tiny bit more $
Old Feb 23, 2005 | 01:07 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
oooo! Another brand to add to the junky audio list!
Old Feb 27, 2005 | 05:14 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Not only crap, European crap.
Old Mar 1, 2005 | 02:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I like that one feature that's listed on the auction...
LED Power Light
Now that's something you don't see every day! (laughs)
Old Mar 1, 2005 | 03:16 PM
ScrapMaker's Avatar
lol what about the "Costant Power"
I wish my amp had CONSTANT POWER!
I guess most amps only have power sometimes??
Old Mar 1, 2005 | 03:41 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
lol myine should be worth its weight in gold...... it has plenty of LEDs and its shiiny
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
