how to power my subs
Old Feb 18, 2005 | 12:21 AM
crazycamaro83's Avatar
ok i have 3 10in alpine type r subs. they are 300 rms and 1000 max watt. can i run a mono amp for all three or do i need 3 amps or any other option. and what about caps do i only need one or more? suggestions
Old Feb 18, 2005 | 10:06 AM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
You have a few choices.
Your best bet is to get a mono amp and run it at2 ohms. You are gonna connect each of the subs two voice coils in series. + to _ to + to -. which will make each sub an 8 ohm load. Then connect each terminal off the box to a mono amp in parallel + of amp to all + of terminals. - of amp to all - of terminals.
Then you would need a amp that pushes 900w RMS at 2 ohms. Maybe a JBL 1200.1. Infinity 1210a. Rockford fosgate 1000.1. Something along those lines.
I would also recomend a 1 fared Cap for every 1000w of power.
If you have any more ?s shoot me a e-mail.
And FYI i am a professional installer.
Jeremy
Wylecoyote08
Oct 1, 2015 09:18 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
