amp problem
Old Feb 19, 2005 | 09:40 PM
crazycamaro83's Avatar
amp problem
ok i connected my am to some 6x9 in my camaro and when i turn the car on they start hissing and when my engine revs it gets louder and then goes back down when it slows down. got any ideas??? thanks dion
Old Feb 24, 2005 | 03:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That can be a couple of different things, usually RPM dependant interference is caused by (in my case):
Rca's being too close to power wire. If you RCAs are run with your amp power wire it'll do this really bad, if you NEED to have them cross paths, make sure it's perpendicular. If they are near each for any distance, it gets noisy. Another thing is your ground, it will make it sound bad either way, and probably worse with higher RPM (right guys?) Check where you grounded the amp, make sure it's a good clean ground.
Only your rear 6x9s are amped? no subs, not the fronts? try fading to front, any noise? if so check the decks ground too. If only the rear, check the RCA's and ground.
Otherwise you can try a line noise isolator, etc, but chances are you can eliminate it with the 2 other suggestions. -J
Old Feb 24, 2005 | 05:16 PM
yeah the rca are right next to the power wire so ill look at that. and all my speakers are amped and im working on a 3 10in sub box for the back so when its all done it should be sweet!
Old Feb 24, 2005 | 05:20 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
lol what 10's
Old Feb 24, 2005 | 05:44 PM
alpine type r's
Old Feb 24, 2005 | 07:58 PM
Car: 2002 SS
Engine: Ls1
not bad
Old Feb 24, 2005 | 08:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, i'd say it's the power wire proximity then.
The most common way to fix this is to run your rcas, all of them, with you remote on, down the center of the car, say on the right side of the console, that way you only really have to take out your passenger seat and rear right seat. (amp is mounted behind rear seat?). And keep your power wire in the far right side. They each go to different sides of the amp, so this way they should basically never get within more then 1' of each other (at the amp).
-J
Old Feb 25, 2005 | 03:00 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
run the power down the passenger side rocker panels and the rcas down the driver side
Old Feb 27, 2005 | 05:28 AM
CrazyHawaiian's Avatar
Car: too many ...
I think its your amp ground. Whenever I've had ground problems, the static got louder if you rev'd it up. Re-check the ground connection, sand down where it mounts to the frame and sand down the connector for a good connection.
Old Feb 28, 2005 | 12:08 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
run the RCA's on one side of the car, and the power on the other side
btw you'd be better off with 2 15's than 3 10's...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
