No Power
Old Mar 9, 2005 | 03:43 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
No Power
Ok here it is me and my friend installed a Dual XD 7500 in a 98 hyundai tiburon....we bought a concector to the stock wiring and we hooked it all up and went to turn it on..no power..checked the fuses and they were all good and all the wires were connected..unsnapped the connector plugged in the stock radio and plugged in the power..one again nothing!!!!! Checked the fuses again....audio fuse was blown in the box replaced it and tried each radio again nothing...the only thing i can think of would be the ground but im not sure how to redo it. Should i just splice the ground wire comming off the stereo and run a new ground or do i have to mess with the factory wire???
One of my friends also mentioned maybe running a new power cord from the unit to the battery..not sure how to do that either...just splice the yellow wire and run a strait wire to the battery??
Old Mar 9, 2005 | 04:18 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
try new Ground. If that dosent work try running a new SWITCHED power off the fuse box or steering colum wireing to the RED wire off the radio. Run CONSTANT power off fuse box or steering colum to the YELLOW wire off radio. IF still nothing then the radio is bad.
Old Mar 9, 2005 | 04:25 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
can you explain a little more about the switched and constant from the fuse box?? i know how to run a new ground now. Just not sure how to hook up a switched or a constant from the fuse box?? maybe some pics??
Im not sure how the wires go from the back of the fuse box
Old Mar 9, 2005 | 04:27 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
switched power = ONLY hot when key is ON
constant power = ALWAYS hot
Use a multimeter to test or take it somewhere and have it done
we charge $35 at circuit city.
Jeremy
Old Mar 9, 2005 | 04:38 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
dont have any money for that....is there any way u could tell me how to hook it up maybe?? could i just run a hot from the battery with like an inline fuse??
Old Mar 9, 2005 | 04:39 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
yeah for constant you can but not switched. For switched tap into the yellow or white wire coming off the ignition harness.
Old Mar 9, 2005 | 04:44 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
nm its not a camaro. Run the switched off the ACC fuse in the fuse box.
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
oh and these forums are for Third Gen only related topics so this will probably get locked soon.
Old Mar 9, 2005 | 04:48 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Will the battery run down if i dont hook it up to a switch if i run it constant?? Thanks for all your help. Never had any trouble at a Circuit City except here in Lafayette, IN. The road shop took off my pin on hood which would still raise from the front and stay up and scratched the hell out of it when the installed my neons. I love my car and im sure you do too. Also felt uncomfortable walking in there and hearing one of the installation guys saying... DAMNIT!! oh well there getting a radio and thats what they wanted...
If i lived where you do..you would deffinitly be my guy to get sh*t done right
Old Mar 9, 2005 | 04:53 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
well if you want you can hook the yellow and red up to the constant from the battery. But you will have to turn the radio on and off manualy
Old Mar 9, 2005 | 05:02 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
and if i wanted it switched i would run a wire from the battery to the yellow wire comming off the radio and run a wire from the ACC fuse to the Red wire comming off the radio. Would i need a fuse on the wire comming from the battery?
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
