Amp Power cable Installation
Old Mar 23, 2005 | 04:47 PM
Kaas's Avatar
Car: 89 Iroc-Z
ok guys, me and a buddy got my subs and amps installed...everything except that damn power cable to the bat.
Can anyone show me a pic of where they ran thier's from? I read one post on here where people say there is a wire loom by the passenger door inside the fender, we tried that, wouldn't go thru.... and i am against drillin a hole in my firewall....let me know guys...gonna finish this project up tomarrow (if we get some good weather....damn rain) PICS IF YOU GOT EM!!! will help greatly
Old Mar 23, 2005 | 05:39 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i went through an existing hole in the firewall on the drivers side, it was the hole that had a gromet and the cable for the hood release, i pushed the gromet in and then enlarged the hole with a file . that was a fine spot to use.
Old Mar 23, 2005 | 06:27 PM
ryanL04's Avatar
Car: 89 firebird XS
Engine: rawr
Transmission: rawr
yeah my firebird had a pre-existing hole in the firewall on the drivers side. i ran mine from the back, through the side panals next to the door, then underneath the passanger seat and through the middle console beacuse i had to get to the drivers side. my rca's were already ran on the drivers side so i couldnt put my power there as well. nothing is visible unless you either take out the driver side seat in which you can see a hole maybe foot going from the passanger side panal to underneath the middle console.
either way, point is your firewall i believe already has a hole in the firewall to run the wire though.
Old Mar 23, 2005 | 07:08 PM
Kaas's Avatar
Car: 89 Iroc-Z
Pics from either of you guys per chance?
Old Mar 24, 2005 | 07:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Why are you so opposed to drilling a hole? The passenger side kick panel near the antenna wire is a perfect spot to drill a hole, toss a grommet in and run the wire through. It's a 5 minute job.
Old Mar 24, 2005 | 12:52 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
what's all this fuss about the passenger side...?
it makes MUCH more sense to go through the driver's side... unless your cars all have the battery mounted on the passenger side... some how...
you want a power wire as short as possible... and drilling a new hole is really easy.
Old Mar 24, 2005 | 01:32 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
My bat is on the passenger side...yours isn't??? I was under the impression that's the stock location:
Old Mar 24, 2005 | 02:12 PM
Jim85IROC's Avatar
Most Camaros have the battery on the passenger side, and most firebirds have it on the driver side. Various models differ.
Whatever the case, it's usually easiest to run the wire down the same side of the car that the battery is on.
Old Mar 24, 2005 | 04:09 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
they change it up , the 82 trans am with a carb and ac its on the passenger side, and on the 85 with tpi and ac its on the drivers side. and my bros 88 firebird with carb and ac is on the pass side.
Old Mar 24, 2005 | 04:18 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
My 89 gta's battery is on the drivers side, but i ran my 4 guage power wire through the area where the wire lume is behind the kick panel on the passenger side just beacuase it was easier. A friend of mine drilled a hole near the firewall in his newer caddy installing a stereo and drilled right into the cars wireing causing a huge mess so be carefull.
Old Mar 24, 2005 | 07:05 PM
ScrapMaker's Avatar
all you have to do is check behind the area where you are drilling... not brain surgery..
well that's interesting that they moved the location around so much... very interesting.
where did they put the intake/airfilter on the passenger side battery locations?
Old Mar 25, 2005 | 07:03 AM
Jim85IROC's Avatar
It's not brain surgery, but you can still make a mistake if you aren't super careful. When I ran the wire in my GTA, I double and triple checked before drilling. That still didn't stop me from drilling right into the body of the clutch master cyllinder. Because it was mounted on an angle, I failed to realize that I actually had less room than it appeared.
Old Mar 25, 2005 | 03:20 PM
ScrapMaker's Avatar
is that master cylinder right up against the firewall? I'd just have someone in the engine bay, verifying I got the hole right before it goes all the way through.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
