Will it fit?
Old Apr 27, 2005 | 03:57 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Will it fit?
Will a 98-02 radio/cd fit in the radio slot, and fit the ThirdGen faceplate?
Thanks, Cocacolakidd.
Old Apr 28, 2005 | 08:01 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A member here did it. Only minor modifications were necessary. I believe at the time he did it, he gave a play-by-play rundown that should give you all the info you need.
Old Apr 28, 2005 | 08:17 AM
Car: 84Z & Porsche
Will it fit?
I searched for that, but I will search more. Thanks, Ed.
Old May 8, 2005 | 02:21 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
pretty sure it's the same din... the only modification I can think of is depth? maybe remove that metal bracket in the din opening at the rear...
Old May 8, 2005 | 02:59 AM
Car: 84Z & Porsche
Will it fit?
I searched and found a thread describing the install. The biggest obstacle was the AC/heater vents go through the rear lower area, and have to be cut out for the slightly larger Radio/CD to fit. I did not cut out the vents to fit as described, but used a steel bar approx 1” dia. heated to gently mold the vent plastic. I was able mold them inwards until the radio/cd cleared. Would have been neat to have the AC vents open in this area to cool the radio/cd, but I have a AC delete now - Oh well. Then again when the heater is blowing I felt it may over heat the unit somewhat, so the vents remain closed this way. Thanks every one for allot of help, Ed.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
