Sony car stereo faceplate?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
what happen to my faceplate? I got in one day and cranked the car up and my stereo faceplate quit working? no colors no nothing? the stereo still works and also play CD's but I cant see anything on the faceplate....the remote doesnt work anymore either.
I took it off and cleaned the contacts but still does the samething.
what could have happened and how can I fix it?
thanks!
thanks!
Car: 1971 Camaro
Transmission: TH350
check the contacts on the deck to see if any are pused in to where it wouldnt make contact with the face, also check the contacts on the faceplate for dirt or corrosion. if none of those work some sony decks have a reset button behind the face on the deck or on the face try pressing the button in for a few sec and try resetting the deck, if there is no reset you can try unplugging the harness from the back of the deck.
If none of those work then i'd say its the face or something in the deck has gone bad.
its a Sony CDX-M730
everything works on it except the faceplate... when the unit flips down...I have no lights or anything whatsoever...
Car: 89 IROC-Z
Engine: 355 TPI
No alignment for that one. Just a bad ribbon cable to. The black ribbon cable to the faceplate on that one goes open ALL the time. If it's still under warranty, send it back to get fixed. Stinks that a $10.00 part F'ed you. But VARY common on ALL the black flip face Sonys. Sorry for the bad news.
so you mean even if I got another faceplate it still wont work? its internal in the unit?
Car: 89 IROC-Z
Engine: 355 TPI
Well a little internal and a little external. A new faceplate probably will not help. Let the face fold up and look under the right hand side or the faceplate. It may help if you then take the removable portion on the faceplate off at this point. You’ll see a small flat ribbon cable, it’ll be black and go from the gray part of the faceplate into the HU. These fail all the time on these unit’s and cause just the problem you’ve described.
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
