Wierd Noise From Subs
Old Jul 2, 2005 | 12:06 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Everytime the stereo turns on (start car, change cds), i get wierd noise from the subs. i think theyre sucking in, making a kind of bloop noise. what could be causing this? it didnt use to do this, it just started a few days ago
Old Jul 2, 2005 | 07:29 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
What’s the make and model of the HU and amp? Could be a ground problem.
Old Jul 2, 2005 | 12:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
heres what my system consists of
Pioneer DEH-6400 HU
Kenwood KCA-746 Amp for the components
Infinity Reference 4x6s
Inifinty Kappa 6x9s
Alpine 3555 Amp for the subs
2 10" Audiobahns in a sealed box
i will check the ground, but i dont think its the problem, unless a connector is loose or something, theres no interference otherwise besides the wierd noise
Old Jul 6, 2005 | 11:46 PM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
Transmission: Probuilt 700R4
It is definately a turn-on thump...why it is just starting now is curious.
Are you running a relay for your remote turn on circuit? Maybe your remote turn on output of the headunit is giving up the ghost.
Usually you can get away with running 2 amps without using a relay, but your headunit is really only outputting like 200mA off that circuit.
I would try getting a spdt relay,
Wire 86 to a POS
Wire 85 to Grnd
Wire 87 to remote out from HU
Wire 30 to remote in on amps
This will cost you $5.00 and assure you will never wear out your remote circuit on the HU and likely will resolve your thump as both amps will power up at the same time.
Hope this helps,
Tuck
Old Jul 7, 2005 | 02:03 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
will the people at the parts store know what im talking about if i wonder in and ask for an spdt relay, or is it a sound store related thing? is POS power source?
Old Jul 7, 2005 | 07:34 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The DEH-P6400, note the "P". Relay wouldn't help this. Get you hands on a DMM. You need to measure the resistance from the RCA ground to the chassis ground on the HU it self. I think that you've got an open/high resistance ground on the RCAs. This was the first HU to start having BIG problems with this.
Old Jul 7, 2005 | 09:51 AM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
Why would you think it just started to happen?
It he hasn't unhooked anything I wonder what changed on his grounding.
You haven't installed any new components have you?
The reason I was thinking it may be turn-on circuit related was becuase if your equipment requires a certain voltage to turn on, and your HU may be wearing out on the turn on circuit from being overworked for some time, is only sending 1/2 the necessary voltage and that would be causing the thump.
He is right though, because turn-on thump is caused by the amplifier already being "on" when audio signal is introduced to it from the head unit.
I was thinking backwards.
You should always use a turn-on relay setup when running 2 or more amps though!
If you find that your ground source is good, you could always install a turn-on delay module- PAC makes one and crutchfield sells them. It is a band-aid though.
Tuck
Old Jul 7, 2005 | 10:20 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Tuck
That's not what happens though, not with a Pioneer anyway. Just because it worked when you put something in doesn't mean you did the job right.
Old Jul 7, 2005 | 10:24 AM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
What happens with the pioneer unit?
I guess I don't understand what is being debated and what was done wrong as nothing has been done.
Old Jul 7, 2005 | 12:01 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Just because the ground was 'Ok for now' when it was done doesn't mean it's a good ground. Rust and/or oxidation could have developed. Vibration could have shook things loose. It may have been bad, but the last base CD had the amp pulling more current. More current means more voltage drop, more voltage drop, the greater the difference in the ground points. Ground must be ground, zero needs to be zero.........
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
lanceflame44
Sep 25, 2015 12:28 PM
