Fixxing stock '91 CD player....where to look?
Old Jul 4, 2005 | 01:08 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I might buy a stock CD player from a '91 T/A, but the owner says it's showing a code, the volume button is worn, and there's a crack in the lens. Is there a place that can fix these problems? Can any radio shop fix it?
Old Jul 4, 2005 | 06:23 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Unless you're building a show car there really isn't a reason to use a beat-up stock cd player.
The code you're referring to is probably the "LOC" code check out this thread for it --> https://www.thirdgen.org/techbb2/sho...hreadid=263851
Some dealers will charge you $40-$100+ to fix that and it only takes a few minutes.
As for parts worn, I guess you could try getting another donor unit and making one good unit probably. My GF's Alero had a problem with it's stock CD player. Basically it was a sticky CD Tuner Button, sometimes it would work if it got really hot outside other times it wouldn't. We called around and the cheapest place we found was $45 bucks to look at it and they didn't even know if they could fix it. I went and bought a replacement cd player (stock) off eBay for ~$30.
I wouldn't even waste the time trying unless you can find a place to fix it cheap. If you plan on upgrading to different speakers just get the aftermarket hu and call it done.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
