I need help with wiring
Old Jul 24, 2005 | 11:29 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
I've searched and searched..and when i think i understand what i need to do..i find something else thats totaly different. I need help wiring my subs to my amp in 2ohm mode..
I have the Rockford Fosgate P5002 amp
http://www.rockfordfosgate.com/produ...h%20Amplifiers
And 2 Volfenhag ZX4712DVX subs
http://www.eslake.com/item/ZX4712DVX.html
The subs are dual 4ohm voice coils and the amp is 2 chan. that can operate at 2ohm or 4ohm. I've only got one coil hooked up per sub. I wanna get my bang for my buck outta the subs/amp. Someone told me I need to use only one channel to hook them up, and someone else told me I need to use both..I'm lost!! If someone can show me in a picture how to wire them up, I'd be very thankful. Thanks guys.
James
Old Jul 24, 2005 | 11:54 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
this page should answer all of your questionshttp://forums.caraudio.com/vb/showthread.php?t=31984
Old Jul 24, 2005 | 11:57 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Is that what I should do?
Would it be more powerful than just hooking up one coil per sub? and, do i only use 1 chan. on my amp?
Old Jul 24, 2005 | 11:59 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
ugh I'm so confused...
or do i do this one?
or is 1ohm too much for my amp?
I'm sorry, I'm too confused lol
Old Jul 25, 2005 | 12:05 AM
traksta15's Avatar
Car: on the hunt for a 3rd gen again
assuming the rms is 500watts apiece you can't use that amp. That amp is 500watts X 1channell. You can see in the link you can only wire (2) dual 4 ohm subs to either 1 or 4 ohms. Your amp isn't 1 ohm stable, so you need a new amp.........or new subs, i'd go with new subs imo............hope this helps.
Old Jul 25, 2005 | 12:06 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
so, hooking them up to their own chan. using 1 coil is all I can do?
Old Jul 25, 2005 | 12:12 AM
traksta15's Avatar
your subs should of came with a warning on using both voice coils on each sub. I've never used only 1 vc, but i know you're supposed to use both...in the 250rms range, look at the memphis PR series, very good for the money.......my friend has 1 15 in his 98 silverado off that same amp and it pounds.........
Old Jul 25, 2005 | 12:22 AM
traksta15's Avatar
Old Jul 25, 2005 | 12:23 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Would it be better if I used 1 sub, hooked up using both voice coils? Would that sound better than the 2 subs running on 1 vc each?
i don't have money to buy any new subs or amp, so thats outta the question.
Old Jul 25, 2005 | 12:29 AM
traksta15's Avatar
with (1) dual 4 ohm vc sub you can wire it to 2 or 8 ohms........if you'r low on cash, sell the volfenhags and use that money......
Old Jul 25, 2005 | 12:32 AM
traksta15's Avatar
Old Jul 25, 2005 | 12:41 AM
traksta15's Avatar
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
