tweeters!!!!
Old Jul 25, 2005 | 11:01 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
tweeters!!!!
my brothers gonna be getting a new headliner for his t top iroc. and he was talking about putting a couple of tweeter in it before we install it. ive seen people with tweeters randomly placed. but i never knew how they wired them. any suggestions?
Old Jul 26, 2005 | 07:36 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: tweeters!!!!
Originally posted by dan_o_89_rs
any suggestions?
I got one, don't do it...
Old Jul 26, 2005 | 09:16 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Component sets have tweeters/crossovers built in. A tweeter running off your head unit aside from other speakers running off it will sound bad. If you need to do door speakers.(component set) or kick panels.
wiring isnt a big deal. Panel arent hard to remove. Id have him look into a c. set though before randomly placing a head unit powered tweeter without any kinda of crossover network.
Old Jul 26, 2005 | 10:33 AM
Car: 89 camaro rs
Engine: 305 tbi
okay, correct me if i am wrong. but a 'compenent set' would be like the 4x6's and the 6x9's that have a built in tweeter? and as far as the wiring, that not really what i was concerned about. more on where and how the wires hook up to the head unit.
he said something about running the wires from the dash speakers. how would this work? that sounds like the stereo wiring in my room, 3 speakers playing from one port, and an junk 8" car sub from the other port. haha.
Old Jul 26, 2005 | 12:26 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
You are thinking of coaxials...
Coaxial:
http://www.crutchfield.com/S-xyGj3km...0&I=113KFC6959
Component:
http://www.crutchfield.com/S-xyGj3km...400&I=108607CS
By the way, not recommending those necessarily, totally random.
Old Jul 26, 2005 | 12:36 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
yup what he said. Component sets offer much more of a clean sound the coaxs can. because the sound is sepperated and the woofer only plays certain freq and the tweeter play only certain freq plus when you amp them you can fine tune it to sound as you want.
Like I said dont bother with the 4-6s in the dash. Find an opening in your door/kick panels to fit. 6.5s or 5 1/4s. If you dont take too many passengers you might be able to do away with 6-9s and save the money more towards your component set which might be a little pricey even on ebay.
Old Jul 26, 2005 | 11:18 PM
traksta15's Avatar
Car: on the hunt for a 3rd gen again
my friend has his tweeters dangling from his t-tops.............
Old Jul 27, 2005 | 11:57 AM
Car: 89 camaro rs
Engine: 305 tbi
well if we did it, i hope we could get them so they didnt "dangle"
Old Jul 27, 2005 | 04:58 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Throwing speakers in randomly sounds bad. I wouldn't want treble blasting from a few inches away from the ceiling either. Seems to be totally pointless.
Old Jul 27, 2005 | 05:36 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
First, like others said, you need a comp set... meaning, it has a tweeter, woofer and a crossover. If you search hard enough, you can find a tweeter set with a 4" woofer, which will fit in the 4x6 speaker location in your dash. However, if you have AC, you might need to do a little bit of modification on the drivers side to get it to fit in properly... which isn't that big of an issue. It really depends on how deep the magnet is on the woofer.
I have a set of Rockford 4" comps in my car... however, I decided to install the tweeters in the A-Pillars. I had to do some modifications to make the woofers fit in the dash. If you decide to get a bigger pair, you'd have to make some kick panels... if you were to go that route, I would personally just put the tweeters down in the kicks, instead of up in the headliner.
If you decide to go with a 4" set of comps, and put the tweeters in the headliner, installation would be rather simple. I chose to mount my crossover underneath the dash - it's not that hard to get to, but out of the way, and realative to the location of my speakers/tweeters. You would run the wire coming from your headunit (or amp if you're running these from an amp) to the crossover. From there, one set of wires would run to the woofer, and the other to the tweeters. I believe the easiest way to get the wires up in the headliner without seeing them, would be to run them beside the dash (tuck them behind) and then up through the A-Pillar, and then under your headliner to wherever it is that you decide to mount the tweeter.
Prior to deciding where you're going to mount the tweeters, I'd do a "preinstall" and just hook everything up lose. Hold the tweeters up where you're interested in putting them, and also try out some other locations to find a place that they sound best to your ears. Depending where you mount them, the highs might be over-bearing, and it will make your system sound like ***. After working that hard to do a custom install, it would seriously suck if that was the outcome.
Hope that helped!
tcflint
Sep 14, 2015 04:55 AM
Omega
Aug 10, 2015 12:46 PM
BowtieFever
Car Audio
Dec 20, 2001 10:13 PM
CamaroZ_85
Car Audio
Mar 27, 2001 05:36 PM
Buck Mustard
Car Audio
Sep 19, 2000 09:24 AM
