Can somebody please verify this?
Old Aug 3, 2005 | 09:14 PM
dpav's Avatar
This is my idea, please tell me if this is a good way to wire these subs. I would like to get 2 Kicker Solobaric 12" subs.
Frequency Response: 20Hz-100Hz
Efficiency: 87.4dB
Impedance: Dual 4 Ohm
RMS Power Handling: 750 Watts
Peak Power Handling: 1500 Watts
Mounting Depth: 6-13/16 Inch
So If I run both of these subs in parallel in a nice sealed box I would need a 2 ohm mono-amp and I could push 1500 Watts to the subs? does this sound correct? I wouldn't have any troubles or worries about the subs blowing due to poor wiring decissions or giving them too much power? Thanks
Old Aug 4, 2005 | 05:58 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
never look at max output RMS is what you want to look at.
Old Aug 4, 2005 | 10:34 AM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Re: Can somebody please verify this?
The only usable ohm load u can create w/ those subs is 1ohm or 4ohm. Make sure u buy an amp that puts out it's most RMS power at either of those ohm loads. Of course, that would probably mean a 2ch Class A/B amp for a 4ohm load, and that would be problematic for that kind of power. So look for a Class D monoblock that is 1ohm stable and puts out about 1500WRMS into 1ohm.
U shouldn't blow the subs as long as the box is built properly, u set the amp's gain correctly, and u don't crank it up to the pt of distortion.
Old Aug 4, 2005 | 10:44 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
your best bet is looking for a decent 1 ohm stable amp..... a decent 2 ohm stable amp that puts out enough RMS power to give it what it needs at 4 ohms... would cost you an arm and a leg over the 1 ohm stable amp....
Old Aug 8, 2005 | 08:02 AM
dpav's Avatar
Ok guys thanks a lot!
Pinguiclia
Oct 12, 2015 04:47 PM
AmorgetRS
Sep 28, 2015 09:33 PM
camarohelp
Sep 22, 2015 03:19 PM
david068513
Sep 18, 2015 08:37 PM
manifoldsrme
Sep 17, 2015 11:40 PM
