will this work?
Old Aug 8, 2005 | 10:49 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
will this work?
Ok i currently have a sony xplod deck a MTX Thunder 4202 amp 2 chanel 280 wats running 2 12" kenwood tornados. I am getting a 15" concept sub and a verge amp 2-channel....i dont know the specs of these. Can two amps be bridged that arent the same and would it be ok? I thought about either bridging the amps and running just the 15 or using both amps seperatly either the mtx amp to the kenwoods and the verge to the 15 or the other way around. How would i go about bridging the two amps if it is possible and how would i go about running the amps seperatley to the subs?
Any advice would be helpful on this...i have never dealt with two amps before.
Old Aug 9, 2005 | 06:23 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
im confused which subs are u keeping? Why not keep either one set or the other and use the other amp to power your front/rear speakers? More information would be useful. How many watts RMS your running, etc
More info...
Old Aug 10, 2005 | 10:14 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
are you trying to bridge two amplifiers together?
because only a few select amps in the world are capable of that... and those are high-end amplifiers.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
