Amp Help
Old Aug 11, 2005 | 12:49 AM
Kaas's Avatar
Car: 89 Iroc-Z
Amp Help
Alright guys, i just installed my new amp earlier today (or yesterday as it is almost 2:00am here) anyways...i got the new Alpine MRV-F545 to power my front and rear speakers. I hooked it up with a 4 gauge wiring kit. the amp is a 500+RMS amp (it is 125 RMS per channel) i have it hooked up right now currently with the 4 gauge wire till i can get my cap in the mail to hook it up with that to run off to the 4 channel amp, and then my mono for my subs. But right now i am having a problem. I'll be drivin, then my amp will shut off, and they the LED screen thing will show the code for excesive current. Any ideas to fix this? should i up the Hz to it? my speakers are rated at 60 RMS for the fronts and 100 for the rears
Old Aug 11, 2005 | 01:01 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I would like to know too. I do not have that problem and i run two amps... but it is something i would like to know just in case i run into it in the future
Old Aug 11, 2005 | 01:12 AM
Kaas's Avatar
Car: 89 Iroc-Z
well, right now i am running them both on different power wires
Old Aug 11, 2005 | 03:32 AM
mm ok.. I have both of my amps hooked up to the single cap, and then that just wired right to the battery
Old Aug 11, 2005 | 07:16 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
G0d, more Alpine stuff. Check the speaker connection. Check that they are tight and have NO exposed wire. Then check the resistance of the speakers. If all is OK there, take the amp back.
Old Aug 11, 2005 | 11:34 AM
i am taking it you do not like alpine.. many problems with it?
(glad i have my infinity amps)
Old Aug 11, 2005 | 01:22 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I repair car audio product. This year Alpine dropped the ball, quality is in the toilet. Manufacturing problems, engineering problems, quality control problems. I can't believe how fast they went to the dark side. Still good sound in all honesty. Sorry...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
