power surge...!
Old Aug 16, 2005 | 05:37 PM
cross_fire3's Avatar
Car: 83 camaro z28 cross_fire
power surge...!
i have two 1000 watt amps and ill barley turn up the volume and every beat makes the lights dim. i have a red top optima battery and a 2 farad cap a stock alternator and all the ground cables go to one ground. is there anything i can do to help out the surge??
Old Aug 17, 2005 | 07:32 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
For the "big three". I'd start there.
Old Aug 17, 2005 | 07:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Good advice. If you do the big 3 and you still have issues, it might be time to look at getting a bigger alternator.
Does your car have air conditioning? If not, it's got a tiny alternator already. If it does have a/c, you should have around a 100 amp alternator, but considering the age of your car, there's no telling if the right alternator is still there.
Old Aug 17, 2005 | 01:57 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
you should put quotation marks around your "1000 watt" amplifiers...
maybe even... 'amplifiers'?
you can slap me when you post your eclipse/jl audio/memphis/(old)phoenix gold model number
also the capacitor is like a band-aid for the real problem... I bet your amp power wire is too small, or pinched/damaged
what size power/ground wire are you using?
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
