what amp for this sub???
Old Aug 21, 2005 | 04:32 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
i was wondering if someone could help me find an amp. or at least tell me what i need to look for in an amp.
here is a link i got from jlaudio with all the specs of this sub. its the 12W4-D4.
i have no idea what i need. im on a budget, this is a used sub; however it seems to be in good shape. i had an audio shop test the coils. they were good. thanks in advance.
Old Aug 21, 2005 | 06:39 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i used to have 2 of those in my camaro. they slammed. i had a top of the line (in 2000 anyway) alpine v12 amp running them, i believe it was 1200 watts. i think they're only rated to handle 500 watts or so.
are you only planning on running one speaker, or do you plan on possibly upgrading in the future?
Old Aug 21, 2005 | 09:04 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I got 3 of these for 70 bucks each because of their 105% price match system. I am putting them in a custom install with 3 Pioneer TS-W256DVC subs. I know that they aren't the best but I heard nothing but good things about the reference line of amps. Thought I would give them a try. Just please stay of away from the Sony XPLOD amps. I bought two for my Alpine Type-Rs and returned them three times because of overheating problems.
Old Aug 22, 2005 | 04:05 PM
Car: 89 camaro rs
Engine: 305 tbi
well for now, im only using the one. main reason: money. second reason: the box i am building is only big enough for the one. i dont need a whole lot of bass anyway. (i will probably change my mind when i get this system going)
i was told i should go with 500w. i just wanted to see if anyne else agreed.
would 600w being pushin the limit or what? because i want all i can get, without ruining the sub.
Old Aug 22, 2005 | 04:37 PM
Car: 89 camaro rs
Engine: 305 tbi
another question...
in order for me to have a remote, or "bass ****"(as i call them), does my amp have to have any special feature for this? if so, what should i look for when reading features on a amp? because this is the only way i wanna do it.
Old Aug 22, 2005 | 04:52 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
You need to look for an amp that has a bass **** connector on it. If you click the link I made it says on their that it has one. That is what you need to look for on the amp specs/features. Some amps have it but you need to buy the **** separate. Some amps are also **** specific. In other words, you will need to buy their/brand specific ****.
Old Aug 22, 2005 | 05:14 PM
Car: 89 camaro rs
Engine: 305 tbi
this does look like a deal... ive gone to almost every site listed in the sticky... you're pretty happy with this amp? where did u find the better price?
Old Aug 22, 2005 | 07:15 PM
1meanGTA's Avatar
my elemental designs nine.1 comes with a bass ****. its 900x1 at 2 ohms and 1200x1 at 1 ohm, but they are underrated and most produce over 1400 watts if you can give them 14.4 volts. it would be more than enough to run that w4, probably wouldnt only turn it up halfway at 2 ohms. if you decided to run 2 12's or even 15's int he future, it will be plenty of power unless you're talking 3 and 400 dollar speakers that need 1500+ watts to get moving.
mine is turned up about 3/4 of the way at 1 ohm to my 2 rl-p 12's, and it beats down. they're cheap for such a powerful amp, i paid 300 shipped for mine. they had a warehouse clearing deal, i dont know if you can still get it for that price, normally they are 350 shipped.
i believe eD's site is www.edesignaudio.com
Old Aug 22, 2005 | 10:44 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
I haven't done the install yet. I am awaiting the packages. I found it for 79 on fry's electronics i believe. I contacted cardomain.com for the price match and they said 70.95 and I said "I'd take 'em."
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
