got my speakers in
Old Oct 13, 2005 | 05:49 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
got my speakers in
okay fellas just letting u know i just got my brand new kicker 12 l7 dual 2 ohm subs in today... now all i gotta do is build a new box top and probably put a divider in the middle cause ive heard mixed reviews of if a divider is needed. then run the power wire off my cap for my amps for mids and highs and ill be back in buisness. ill get pics of it all once i get my amp box built in a week or so.
Old Oct 13, 2005 | 08:25 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Assuming you're wiring in mono the only thing the divider will do is cost you air space. When one sub is compressing air, the other will be doing the exact same thing so the wall wont matter. The only time it would matter is if the subs will be following diffrent paths (ie wired in stereo, hooked to amps with diffrent outputs, or wired wrong).
Old Oct 13, 2005 | 08:37 PM
Engine: 305 tbi l03
nope ill be wiring them in paralell to the same amp (mtx 81000d amp) should come out to be a lil less than 1 ohm load...if they dont like it i will have to wire them in series to about a 2 ohm load.
Old Oct 13, 2005 | 09:01 PM
Gummie's Avatar
Car: 88 GTA
When I was talking about messing up wiring, the only way you could do so is if both subs are DVC and one is wired in series and the other is in parallel. That or they're out of phase because a + and - are switched. Again, you don't need the wall if they are wired the same and in mono.
Old Oct 13, 2005 | 09:17 PM
Engine: 305 tbi l03
no either way i go both will deff be wired the same...im not one of those people that only use on coil on a dvc sub thinking thats how series is wired...lol...but thanks u just saved me a lot of heart ache then cause my sub box is not equal on each side its formed to the well as good as i could which would mean i couldnt just measure and devide straight in half. thanks i just hope your right.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
