getting it togther, got new amp
Old Oct 14, 2005 | 12:31 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Well the new system for the IROC is comming together. I just bought a new amp to run the entire system.
Kicker KX700.5
5 channel amp. Mixed mode; 4 channel - A/B class amp 85x4 @4ohm stereo and 1 sub channel - D class amp 420x1 Remote bass control, 3 built in crossovers, built-in fan.
Excellent amp in my opinion. Just thought I share and show off a bit. Now, where to mount it?? I'd like to have it hidden... perhaps in the spare tire well.
Anyone got amps or other electronics hidden in the spare tire well or glove box area?? Show me, post some pics - I need some ideas!
Thanks!
Old Oct 14, 2005 | 12:37 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I'm not sure how big that amp is, but you might want to try mounting it in the rear seat. I'm going to attempt the same once I choose my two new amps. Thankfully, I have my tan seat back to test things on before I try it on my black one. Here's a link
Nice choice Isn't a good feeling when things start coming together?
Old Oct 14, 2005 | 12:39 AM
Brisk's Avatar
yes I'd love to mount it in the rear seat, however the amp is nearly 24" long.. and I'm fairly certain that it won't fit (darn it!)
I'll have to measure to make sure.. it would be sweet if it fit!
Old Oct 14, 2005 | 01:02 AM
Gummie's Avatar
Car: 88 GTA
Depending on it's width, maybe you can turn it 90 and mount it sideways
Old Oct 14, 2005 | 07:20 AM
Brisk's Avatar
unfortunatly my rear seats are split, like rear buckets.
I'll have to measure it later today when I get home from work.
Old Oct 14, 2005 | 03:38 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
If you took the end caps off it would fit nicely in a solid rear seat. It might be a little more work, but that could be very well worth it.
Old Oct 15, 2005 | 08:59 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I looked up the dimensions of the amp on epinions.com. All the Kicker amps I've dealt with give the dimensions with end caps installed. These add on ~4-5 extra incles in length.
Width: 10.13 in.
Depth: 22.5 in.
Height: 2.5 in.
...and 82firebird...I can't get enough of your sig.
Old Oct 16, 2005 | 01:05 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If you could get a non split back, it will fit right in.
Old Oct 16, 2005 | 10:09 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
in my spare tire well are the rest of the electronics of the system:
So yes I recommend placing equipment in there
Attached Thumbnails getting it togther, got new amp-carstereoz28-sept-3rd-2005
Old Oct 16, 2005 | 11:24 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Very nice & clean.
Old Oct 16, 2005 | 01:41 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
i myself have a new system waiting for my bird. As soon as i get home from this wonderful country iraq. I will install 2 mtx thunder 8000, thunder 684 amp, cap, and well box . I might also replace the stock speakers. Im thinking of only doing 8guage, for this set up.. Will have pics in dec
Where is the best place to mount an amp? if possible i like to hide it ...
Old Oct 16, 2005 | 04:51 PM
Kandied91z's Avatar
nice amp.. i love my sx amps!
in order from top to bottom. 900.4, 1250.1 and 500.2 i had another 4 channel but i took a set of speakers out to cut down on space. i would mount it either in the lower well area if nothing is there or if you really want it hidden the one should fit on the drivers side where the side compartment is.
Old Oct 19, 2005 | 02:54 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
im not sure if my amp will fit. Its one of the beasty mothers. i have the well box is there actually room under it for an amp, and what about overheating in that area?
Old Oct 19, 2005 | 04:01 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Kandied91z,
Are those in an amp rack? If so, I'd like a closer look, if you don't mind. Looks like an interesting setup.
Old Oct 19, 2005 | 06:54 PM
Brisk's Avatar
ya I think we'd all like to see a closer looks at Kandy's setup...
Old Oct 19, 2005 | 10:56 PM
Kandied91z's Avatar
in time after i have the paint finished.
in order to fit on the drivers side yes you would have to remove the actual compartment/cardboard box. that's just a decision you'll have to make though, the amps look nice enough why not body match the metal extensions and show it off?
either way i'm sure you'll figure something out.
Old Oct 20, 2005 | 12:12 AM
Gummie's Avatar
Car: 88 GTA
The reason why I'm somewhat hiding everything (running grills on everything, installing new amps in back seat, etc) is to keep it out of the eyes of the public to try to avoid theft
Old Oct 20, 2005 | 11:11 AM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
yeah what he said i am putting a well box in the maro with two Perfect 10's and wanted to mount the amps to the floor of the well under the box. Any heat issues here?
Old Oct 22, 2005 | 01:43 AM
Kandied91z's Avatar
i suppose if you daily drive it then it's definately an issue. it seems the more i exposed things the less they were messed with, that and i never leave the car alone.. in the end that's what insurance is for i guess. stereo equipment is too expensive not to have a seperate rider. even with insurance there is no need to attract unwanted attention though.
Old Oct 23, 2005 | 05:10 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
That amp should fit in your back seat. My subs amp is 31.5" long and I thought bout putting it in the back seat. I just couldnt fit that AND my highs amp in there together nicely. So, they sit on the hatch with everything else. Check the pic in my sig. What color is your interior? I might be willing to trade ya back seats, I have the full one. Im planning on getting rid of the back seats anyways, that would just modivate me to get my **** in gear and do it! PM me or let me know!
Old Oct 23, 2005 | 11:02 PM
Brisk's Avatar
ya it wont fit into my rear split seats.. oh well.. I prefer to have it hidden anyway.
my interior is grey.
DISTURBthePEACE - I like your box.. want to make me a similar one?
Old Oct 24, 2005 | 12:24 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
You know, your the second or third person to ask that....maybe I should consider it...let me think it over. It just takes so much time and its built to my subs requirements. I install car audio from 9 am to 6 or 7 pm and I never feel like doing it after work but if there are enough people who want them, then maybe I will consider it...may get expensive though, especially if you want it painted like that too.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
