amp and sub install questions..
Old Oct 15, 2005 | 07:39 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
hows it going alll, i have hooked some systems up before on cars with aftermarket decks and headunits, but my friend wants me to install a system on his 97 explorer and all he has is the factory cd player right now, seeing it doesnt have rca jacks in the back, how would i run them to the amp, and also where is the remote wire hooked up to? any help whatsoever would be greatly appreciated! thanks!
Old Oct 15, 2005 | 11:36 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
You'd need a "Line Level-To-RCA Converter" for the amp inputs. For the remote wire, there may be a wire which comes alive when the radio's on such as an antenna wire. If you cannot find any wire that's live with the radio, you'll probably have to tie into a fuse which is powered only with the key on, but this is not the best idea since the amp would always be on with the key on (and sucking power) even if the radio were turned off.
Old Oct 16, 2005 | 01:47 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Some amps come with internal line level to rca converters built in like this. You won't find many serious amps with them, but then again if you're going to be running anything that high quality you won't want a line level to rca converter anyway.
Link 1: https://www.thirdgen.org/techbb2/sho...e+level+to+rca
link 2: https://www.thirdgen.org/techbb2/sho...e+level+to+rca
Old Oct 17, 2005 | 07:43 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Just for clarification, it's a speaker level to line level converter, not a line level to RCA converter. Also called a line out converter or LOC.
Old Oct 17, 2005 | 07:53 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Hey! That is right...I knew something sounded off when I said it...
I believe RCA is a tradename when referring to cables, isn't it?
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
SPEEDY Z28
Aug 17, 2015 01:46 PM
