Welder's cable for power/ground wires?
Old Oct 25, 2005 | 09:50 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Does anyone have anything against using welder’s cable for power/ground? I’m thinking about picking up 20 feet of 0 gauge because the stuff is dirt cheap (about a dollar a foot). It's extremely flexible, etc. The only downside that I can see is that it's not as pretty as what most of you are running in your cars.
Old Oct 26, 2005 | 07:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As long as it's flexible it should be fine. The big drawback to welder's cable used to be that it was very stiff, but with the popularity of car audio, it wouldn't surprise me if the manufacturers are providing the same stuff to welders rather than make 2 different styles.
Old Oct 26, 2005 | 11:54 AM
Gummie's Avatar
Car: 88 GTA
The stuff is pretty flexible. I got the idea from playing around with my friend's mig welder - it has a 2 gauge grounding cable. I could bend it in a roughly 6" diameter circle without much effort, so it should be more than flexible enough for routing inside a car.
My main concern is how weatherproof (or not) the stuff is. After all, it will have a 6 foot run under the hood.
Old Oct 26, 2005 | 12:39 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I was running 1/0 gauge welding cable for a good while, worked great .
Old Oct 27, 2005 | 01:10 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
Welders cabling is the ONLY way to go... you can get 20ft of 1/0 for like $20... people that buy "car audio cable" are friggin' chumps if you ask me.
it is slightly stiffer, but I've found that it works wonders for our cars, since there is a plastic conduit, of sorts, that runs down the driver's-side door well. There is enough room in there, even with all my power options, for my 1AWG wire to fit.
And remember, they are used for welding, which is one of the most extreme electrical usage scenarios out there! The insulation is nice and thick, and the wires are rated for up to 300v many times.
Old Oct 27, 2005 | 02:09 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by ScrapMaker
...And remember, they are used for welding, which is one of the most extreme electrical usage scenarios out there!...
I can think of more extreme, and they also use 'welding cable'.
Old Oct 27, 2005 | 10:54 PM
ScrapMaker's Avatar
So it's all good, as long as you don't pay for some over-priced crap.
Old Oct 30, 2005 | 02:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
couldn't agree with ya more scrap maker. I bought 1AWG welders cable, on sale for like $.80/ft. Awesome stuff.
The wire is really fine too, kinda surprised me, so it's very bendable. Plus yea, since it's welding wire, the insulation is meant to be dragged around and stepped on a lot, so it's TOUGH.
Hide the wiring under carpet, and no one will ever know.
Old Oct 30, 2005 | 02:56 PM
ScrapMaker's Avatar
It's designed to be stepped on, run over, snagged, tugged on, flexible, and to survive hot metal contact.
So yeah, I think Welding leads work amazingly well... this should be a sticky.
Old Oct 30, 2005 | 04:23 PM
Gummie's Avatar
Car: 88 GTA
It would be my first ever
Seriously though, it is pretty sad that anyone would use something else when there is such a cheap alternative. Even if you're building a show car, odds are you're not going to have the main wire(s) that run from your battery(batteries) to your distrubition block(s) visible.
Old Oct 30, 2005 | 09:30 PM
ScrapMaker's Avatar
hell, just PAINT the wires close to your amp... Make them match your paintjob or something... that's even better
Old Oct 30, 2005 | 10:22 PM
Gummie's Avatar
Car: 88 GTA
You would need some super crazy flex agent to do that and have the paint not crack. Besides, flat black isn't that unattractive; it's not like it's coated with asphalt or something.
Old Oct 30, 2005 | 11:37 PM
ScrapMaker's Avatar
The paint on our bumper covers seems like it would work... you can bend the heck out of those and the paint stays put.
Old Oct 31, 2005 | 09:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
vinyl paint/dye.
Old Oct 31, 2005 | 11:23 AM
ScrapMaker's Avatar
Sharpie!
Old Oct 31, 2005 | 11:32 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Old Oct 31, 2005 | 03:19 PM
Gummie's Avatar
Car: 88 GTA
Sharpie!
Wait, it's already black
Unless they make a high gloss sharpie or something
Old Oct 31, 2005 | 04:36 PM
ScrapMaker's Avatar
they make different colored Sharpies... I guess they probably wouldn't work... damn...
guess maybe spraypaint with a nice flex agent.
or whiteout
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
