disconnect the power Antenna
Old Nov 6, 2005 | 09:29 PM
89GTA2LV's Avatar
Car: 89 Trans AM GTA
Engine: 5.7L
I just got an sirius Satellite. I got the one that runs through your radio FM. I was told that if I have the antenna not go up the reception would be great when I am playing the satellite.
I looked in the fuses and didn't see one that was marked ant.
Does anyone know of a easy way to disconnect to power to the antenna?
Old Nov 6, 2005 | 10:27 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
If you want disable the power antenna going up/down you just need to cut the wire for it in your harness on the back of your headunit. Pull your head out and take a look. The wires should be labeled.
Old Nov 7, 2005 | 07:40 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Is this a stock or after market HU? What's the make and model. And I don't see this doing anything useful unless there is already a station near the TX F of the RF modulator, and most should give you a chouse for TX frequency of the modulator so that shouldn't be a problem. I'd put the thing in, then pull the Rem. wire and see if it made a difference. If not, don't hack the wiring. If it makes things better, try a different output frequency.
Old Nov 7, 2005 | 08:45 PM
89GTA2LV's Avatar
Engine: 5.7L
Its just the normal factory power antenna.
I stopped the one from my other car from going up and the sirius Satellite comes in awesome on any frequency. I just wanted to know of a quick fix and I donot want to cut anything
Old Nov 8, 2005 | 07:08 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Is this a stock or after market HU? If after market, what make and model?
Old Nov 8, 2005 | 09:11 PM
89GTA2LV's Avatar
Engine: 5.7L
Its a stock antenna
Old Nov 10, 2005 | 10:06 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
Doesn't matter if the antenna is up or down your reception will be the same. All you need to do is set the frequency of the wireless transmitter inside the Sirius unit to a FM frequency that is as far away from any other FM radio station as possible. In Orlando FL the best frequency is 88.1 FM because the closest station is in the 89's. If you *still* want to disable the power antenna the easiest way to do it is to cut the power antenna wire behind your radio... it is usually blue with a white stripe or just blue. I wouldn't bother with that though, it's completely unnecessary. By the way I am an installer for Best Buy and I do these installs on a daily basis :P
Old Nov 14, 2005 | 05:23 PM
johnblacksox's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 305 V8 LG4
How well does it work to send the Sirius signal via FM versus hooking it up direct?
I'm debating what to do, I don't want the reception to suck. We have radio stations all the way down to 88.5 here.
Old Nov 14, 2005 | 09:08 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
The reception will be fine as long as you stick with the newer sirius equipment. The wireless modulators in the older equipment (more than say, 6 months old) completely sucked. The Sportster 2 was really the first decent piece they put out quality-wise. Also, I've done this on a daily basis for several years and I've never heard this whole "keep the power antenna down and you'll get better reception thing."
Old Nov 14, 2005 | 10:03 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
If you have a head unit that says "XM Ready" or "Sirius Ready" then you should buy the module for dedicated satellite radio if you're worried about reception problems. With the dedicated units that plug directly into your satellite-ready head unit the signal is digital and doesn't have to go through FM modulation. You would simply select it as another source just like a CD or tuner for FM radio... much cleaner looking than having a portable unit mounted from your dash or windshield and it's better quality sound. The price of the dedicated units is pretty much the same as the portable units - only downside being that the dedicated units are..... dedicated.... therefore they cannot be removed from the vehicle for use in your home.
Old Nov 15, 2005 | 07:37 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The signal at this point is analog, not digital. And he’s using a stock HU but didn’t add that to this post.
Vintageracer
Jan 10, 2020 05:33 PM
mddaniel
Sep 8, 2015 05:16 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Ozz1967
Aug 16, 2015 10:23 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
